3 members (RLB, qside, Gray_Ghost), 71 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#239442 08/20/2007 1:43 AM
I have been trying to decide whether to use two point or three point seatbelts in my AD one Ton. Here is my problem. Quite a few three point setups that I have driven with will lockup when going over a good bump. Mostly this isn't a problem but in my 1 Ton, if this happened in an emergency while trying to access the handbrake, I would be out of luck. What do you think about this dilemma?
1951 1 Ton Completed
#239443 08/20/2007 1:58 AM
think back to how many times this has been necessary and then decide. iam putting in seats with built in three point because i think it is very good thing. Ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#239444 08/20/2007 5:21 AM
Is the inertia system on after market belts as sensitive to bumps as the electric assist units on today's newer vehicles?
1948 AD Pickup
#239445 08/29/2007 4:28 AM
With a metal dash and non-collapsing steering column, I went with 3 point belts to avoid a bump on my head (or a pssanger's) whenever I have to slam on the brakes.
#239446 08/29/2007 5:22 AM
If your hydraulic brakes fail you won't be getting that much force on the seatbelt tensioners. I wouldn't sweat it, use the 3 points.
Paint & Body Shop moderator
#239447 08/29/2007 5:58 AM
Jim & Caroline
#239448 08/30/2007 3:17 AM
Are you keeping your Bolt stock? If not, you could find yourself a couple of front bucket seats out of a 1999 and up Serria/Silverado. Both of these have the seat belts as part of the seat. This way you don't have to worry about fabing up upper belt mounting points in you cab. Plus the have better lumbar support than your old bench probably has.
1950 GMC 3100
Camaro frt clip, 4 link, 6.0L, 4L65-E
More pix on Photobucket
#239449 08/30/2007 2:49 PM
Nthstr,
I am keeping it stock but if I were to change the seats, it would definitely be for the lumbar support. Thanks for that suggestion.
#239450 09/01/2007 1:18 PM
3 point is the way to go. You wont look pretty with that steering column impression in your chest.
1953 3/4-Ton Chevy
More pix
If it can be built ... It can be fixed.
RB53
