9 members (Hotrod Lincoln, 55shaker, MickeyP, 50Chevy3100, frogfarmer, Pre '68 Dave, 3 invisible), 107 guests, and 4 robots.
Topics128,260
Posts1,058,322
Members48,485
So I'v bin doing some work on my truck and it came time to start it up but when I went to it would not start all it does is spin the fan and make some nose( I can't describe it) so I thought I might get some one els insight on what it might be.
here is a vid of it V
http://s95.photobucket.com/albums/l124/Winston_T/?action=view&current=Test.flv
any help would be great
-Tim
No spark or no fuel. Check for spark by pulling a plug wire and setting it close to the block. Crank it over and whatch for a spark to jump to the block.
Check for fuel by looking down the carb and see if it has fuel coming out when you open the throttle. Do this with the key off incase it might backfire. Joe
Truck-Man,
that is a very cool video. It is also very useful. It sounded to me like during that last little bit, it fired and stopped it dead. If that is true, I would say it is too far advanced. Anyhow, my method would be to give it a few ounces of gas prime and then try it.
Good luck and thanks for the video!
1951 1 Ton Completed
Tim,
What a cool way to share your problem...a video! I don't know what kind of work you have been doing, but the first thought would be that you have knocked off a wire or might have some adjustment out of whack!. The audio sounds like it's getting absolutely no fire to the plugs.
If you can have someone crank it while you hold a plug wire near a ground, you can watch for a nice spark.
To prove it's not a fuel issue, look down the carburetor with a flashlight as you work the throttle...you should see the accelerator pump squirting fuel into the throat. Do you have gas in the tank?
Tell us what work you did that might have some bearing on the problem. I love the video, neat idea.
Stuart
I heard no fire. Therefore, no spark, no fuel or both.
1951 3800
-hotshoe
Wish i was that computerraly advanced to post something like that.
Marty
thanks guys for the awesome info!
I looked in to and there was no spark so I'm looking in to that
maybe I'll post a vid of it runnin
-Tim
If this were the 1950's, Id say to check for a potatoe stuck in the tailpipe.
1948 AD Pickup
Q
Apprentice
Apprentice
Q Offline
You havent described the work you were doing on it and that would have helped . Check for gas at the carb and then check for spark at the plug . If there is no spark check the points and then the coil
