| | | Forums66 Topics128,261 Posts1,058,327 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 25 | So I'v bin doing some work on my truck and it came time to start it up but when I went to it would not start all it does is spin the fan and make some nose( I can't describe it) so I thought I might get some one els insight on what it might be. here is a vid of it V http://s95.photobucket.com/albums/l124/Winston_T/?action=view¤t=Test.flv any help would be great Thanks -Tim | | | | | Joined: Feb 2000 Posts: 5,264 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,264 | No spark or no fuel. Check for spark by pulling a plug wire and setting it close to the block. Crank it over and whatch for a spark to jump to the block. Check for fuel by looking down the carb and see if it has fuel coming out when you open the throttle. Do this with the key off incase it might backfire. Joe | | | | | Joined: Mar 2002 Posts: 9,116 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,116 | Truck-Man, that is a very cool video. It is also very useful. It sounded to me like during that last little bit, it fired and stopped it dead. If that is true, I would say it is too far advanced. Anyhow, my method would be to give it a few ounces of gas prime and then try it.
Good luck and thanks for the video! | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Tim,
What a cool way to share your problem...a video! I don't know what kind of work you have been doing, but the first thought would be that you have knocked off a wire or might have some adjustment out of whack!. The audio sounds like it's getting absolutely no fire to the plugs.
If you can have someone crank it while you hold a plug wire near a ground, you can watch for a nice spark.
To prove it's not a fuel issue, look down the carburetor with a flashlight as you work the throttle...you should see the accelerator pump squirting fuel into the throat. Do you have gas in the tank?
Tell us what work you did that might have some bearing on the problem. I love the video, neat idea.
Stuart | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | I heard no fire. Therefore, no spark, no fuel or both. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Nov 2001 Posts: 1,523 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,523 | Wish i was that computerraly advanced to post something like that. Marty | | | | | Joined: Feb 2005 Posts: 25 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 25 | thanks guys for the awesome info! I looked in to and there was no spark so I'm looking in to that maybe I'll post a vid of it runnin
Thanks -Tim | | | | | Joined: Jun 2006 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 272 | If this were the 1950's, Id say to check for a potatoe stuck in the tailpipe.
1948 AD Pickup
| | | | | Joined: Aug 2007 Posts: 23 Apprentice | | Apprentice Joined: Aug 2007 Posts: 23 | You havent described the work you were doing on it and that would have helped . Check for gas at the carb and then check for spark at the plug . If there is no spark check the points and then the coil | | |
