0 members (), 83 guests, and 3 robots.
Topics128,081
Posts1,056,318
Members48,442
#238076 07/30/2007 6:46 AM
Had a guy stop by the house today. He has a '48 3/4-ton w/ orig. wheels (8 lug). Think he said got it from his neighbor. First old anything. Wants to upgrade front to disc brakes but doesn't want to changed his wheels or bolt pattern. Lock ring on rims. Wants to stay orig. but wants safe brakes. Gave him an issue of my Goodguys Mag. and told him about this site. Thought I would post the question for him. See if anyone has info for him next time he stops by.
1954 custom 1-ton (1 of a kind)
#238077 07/30/2007 2:33 PM
I am not an expert, but have developed my oppinions on the issue:
I have also never done it, wondering if it would work.
There is not a kit you can purchase for the 3/4 ton.
Buy brake parts for newer model truck from parts store eg. autozone.com and retrofit them to your truck.
Remove, backing plate and add cylinder bracket, then cut backing plate to fit over and around cylinder. Once the backing plate is cut there is no turning around. Buy 8 lug disk which will fit over front hub. Monkey around with spacing between bracket, spindle, and disk until right.
Buy new wheels 6.5 x 16 and if there is clearance problems use spacers to correct.
Im thinking about trying it.
If this won't work, someone please stop me.
#238078 07/30/2007 2:39 PM
A couple guys on here have posted about doing the retro-fit 8 lug disc brakes. Do a search and see what they did.
Also...just an upgrade to Bendix brakes ('53 and later on the 3600) will be a little improvement.
They are also larger. 12" vs. 11"
Steve
'49 3800
'52 3600
'57 3100
#238079 07/31/2007 2:45 AM
Quote
He isn't the first one to want to accomplish this, but so far there is no kit available.
Its not been difficult to adapt disk brakes to the spindles, the challenge is to mount calipers that will clear the stock wheels.
A little searching here should bring up a thread with pictures and part numbers that one guy came up with.
I found it: Disk Brake Conversion
#238080 07/31/2007 3:33 AM
I would just redo what's there and add a dual res master and a vacuum booster. They had plenty of braking power if they are in good shape. Unless you figure out how to make it go faster than 45 MPH, you won't need any more braking power,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
