2 members (Hotrod Lincoln, Stewart2), 125 guests, and 1 robot.
Topics128,195
Posts1,057,372
Members48,469
Working on the '62 Suburban this week, and noticed something about the inner fenders under the hood, and where they line up with the frame rail.
On the passenger side, the bottom of the inner fender is almost even with the top of the frame rail. On the driver's side, I can get two fingers between the fender and the outside (suspension-side) of the frame. The truck has 45 years worth of light bumps and such with the front bumper, but it doesn't look like it's ever been whacked or punched hard.
But it definately looks like the front sheetmetal is over to one side.
Can anyone tell me if there is supposed to be an inch and a half gap between the outside of the frame and the bottom of the inner fender?
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
Make sure all of the rubber on the cab mounts are in good shape, especially under the core support. They also rust out where they attach to the frame, causing the body to drop on that side,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Apprentice
Apprentice
this is a pic of my 62 unmolested burb before I took it apart I think it is the same as what you are talking about
http://rides.webshots.com/photo/2069745230100350765TzqeOu
it's not how much time you spend on it, it's how you spend your time with it
