| | | Forums66 Topics128,200 Posts1,057,405 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | Working on the '62 Suburban this week, and noticed something about the inner fenders under the hood, and where they line up with the frame rail. On the passenger side, the bottom of the inner fender is almost even with the top of the frame rail. On the driver's side, I can get two fingers between the fender and the outside (suspension-side) of the frame. The truck has 45 years worth of light bumps and such with the front bumper, but it doesn't look like it's ever been whacked or punched hard. But it definately looks like the front sheetmetal is over to one side. Can anyone tell me if there is supposed to be an inch and a half gap between the outside of the frame and the bottom of the inner fender? Thanks, -Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Make sure all of the rubber on the cab mounts are in good shape, especially under the core support. They also rust out where they attach to the frame, causing the body to drop on that side, Scott | | | | | Joined: Dec 2006 Posts: 34 Apprentice | | Apprentice Joined: Dec 2006 Posts: 34 | this is a pic of my 62 unmolested burb before I took it apart I think it is the same as what you are talking about http://rides.webshots.com/photo/2069745230100350765TzqeOu
it's not how much time you spend on it, it's how you spend your time with it
