| | | Forums66 Topics128,026 Posts1,055,409 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Another fine mess my PO got me into. When I purchased my truck the windshield was not installed. The PO told me it was new and he had not installed it yet. A few weeks ago I found out why...I doesn't fit. ...I mean not even close.
The edges of the glass that are in the middle of the split pane are about an inch to large to fit into the frame. I know I could buy a new windshield from LMC or the others. (I am hesitant to just modify this one because there may be other ill fitting sections that are not obvious)
I would like to price getting the pieces made locally but since both sides of mine seem to have been made by the same halfwit I do not have a good template. How would I go about making a template. Does the glass fit inside the pinch weld or is it slightly larger.
Would any one who has their windshield out(preferably one that you know fits) be willing to make a paper template and mail it to me?
I would be very grateful for any help. Rich | | | | | Joined: Aug 2001 Posts: 1,299 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,299 | I would consider calling a windshield installer and seeing if they couldn't just trim the pieces of glass that you have. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | e-mail me your Address , my glass is out and will take just a second to make a template and mail off to you. P.S.my glass fits perfect. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | SW,
I sent my address via your email listed here on the stovebolt page. Thanks a million for the help
Rich | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Greg, I could do that but I concerned that the glass is not right in other areas that might not be obvious. This could cause leaks if other parts are too small, etc. | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | rust bucket,around here a lot of people are taking the middle strip out and joining the glass in the middle,this may be what the po had in mind. ------------ Floyd
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Why are folks taking out the center? The center strip can't block much of the view.
BTW: I have my old windshield in my garage if you are still looking for measurements. | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | Floyd,
The windos seem to fit ok side to side they arw too tall in the middle. If I put the glass on the truck without the gasket and rest the bottom on the window frame by the pinch weld the top is atleast 1 inch past the top of the frame.
Go figure???
Virginiafiretruck, I think SW is sending me a template he is making from a windshield he has out of his truck.
Thanks Rich | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Bucket ...template will be in the mail tomorrow . Rad | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | OOOH update ...remeber to cut that template to the inside of the black line .....lol | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | SW. I got the template. Thanks very much. I plan to check it out tomorrow against my glass to see if it is slavagable. I will let you know how I make out. Rich | | | | | Joined: Sep 2005 Posts: 1,028 'Bolter | | 'Bolter Joined: Sep 2005 Posts: 1,028 | I finally got the time to cut the windshield. My neighbor lent me his diamond blade for my 4 inch grinder. I had little hope that I would not crack the glass. Funny thing is the pieces I cut off cracked into a million pieces but the main glass stayed perfect. I ran my belt sander over the areas that were just a little off and smoothed the cut areas and the windshield went right in.
SW Radial... A million thanks for the template it worked just great! | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Glad i could help Bucket ! maybe some day i will NEED. cool your glass fits now Rad | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | If you cut glass with grinder us water to keep cool. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I am impressed that you cut it yourself and it works well. This is a relatively small city but there is a glass shop in town where the guy still has templates for old glass. Not that you will need it now. but anyone else who might need glass, just inquire of the local glass shop. they may have templates hidden somewhere. | | |
