| | | Forums66 Topics128,094 Posts1,056,487 Members48,444 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 30 New Guy | | New Guy Joined: Jan 2007 Posts: 30 | Hi
61 apache fleetside with torsion bar front suspension. I am busy with replacing worn ball joints and the bushings on the a-arms. This weekend I installed the bottom a-arm and what a story to get the bushings in (Long breaker bar and 3/4" socket. Being new they are really a tight fit into the a-arm. My question is how tight should they be after bottoming out the bushings against the a-arm? Mine is really tight...cant turn the bar by hand any longer. Fitted to the crossmember it is possible to move the a-arm up and down, but it is tight. I really dont want to damage the bushings. Also how do I check the centerness of the bar on the arm? Eyeball? Thanks | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | my expeirience with torsion bars is that you shouldnt be able to turn them bye hand and tight is prob. really good ...as that means you have them preloaded correctly ...Your old ones musta been plain worn out ...Just my 2 pennies | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I'll be doing mine in a month or 2. Ask me later  BTW Where did you get the lower ball joints and how much? If you don't mind me asking. | | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I got a set of lowers from a place on Ebay. Hecho en S. America, but visually they looked like quality castings. They were $75 for the pair, plus shipping.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | When I lowered the front of my truck I took a breaker bar and just urned the torsion bars down, not sure if that means my front end is "loose" or not. I have not even begun the nightmare of maintinence that is my front end. I am waiting to decide anout a v-8 swap, cause if I do that I might ditch the old front end for something newer and more sophistimicated...not sure though.
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Jan 2007 Posts: 30 New Guy | | New Guy Joined: Jan 2007 Posts: 30 | I will just trust then that everything is in order. I got my ball joints from classicparts. $89.95
They seem good quality, but I waited for ages! The upper ones are actually from Moog - I think that is a brand name? The a-arm shafts are my actual problem at the moment. Hope I did not tighten them too much! | | | | | Joined: Aug 2007 Posts: 40 New Guy | | New Guy Joined: Aug 2007 Posts: 40 | Moog is like GE. They make everything from car parts to motors and controls for factory automation to complex high reliability sub systems for commercial and military aircraft.
Bob J | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I think you might have 2 different companies mixed up there. Moog automotive is a subsidiary of Federal Mogul, not related to the other company. However, they do make the best front end parts on the market. I use them exclusively on my cars.
Bill Burmeister | | |
