7 members (Bill Hanlon, Otto Skorzeny, 52Carl, Hotrod Lincoln, TooMany2count, chemanic, 1 invisible),
92
Mod | | | Forums66 Topics128,135 Posts1,056,418 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | does anyone have a recommendation what kind of car to steal it from. i want one that i can crank from inside my suburban to raise and lower the spare | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | hit the pull-a-part and start crawling under some later pickups or vans. some cars have them also the mechanisms will be cheap and you can get the complete unit with the mounting bolts. | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | i am sure great minds think alike. i will be there friday after work | | | | | Joined: Apr 2005 Posts: 507 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 507 | Try some of the late model Astro Vans and the full size Chevy pickups.
"If it ain't Steel it ain't Real" "Earth the insane aslyum for the rest of the Universe" 41 1/2-ton, a work in progress 68 Shortbed stepside 327/325hp/700R4
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | '88-'98 Chevy or GMC full size, preferrably a 3/4 ton 4x4, though any of them can be used with minor alterations to the end. I had to slightly widen mine with a plate to make it fit the hole in the rim and actually hold it up.
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | My dad's Dodge minivan has a lug sticking up through the floor that requires the use of the tire iron. It's inside the tailgate and I believe it uses a 3/4" socket size. Just a thought, Scott | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | what year is it and what model the chevy pickup ones crank from the outside i am looking for one the cranks from the inside | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | The Dodge was an 89 I think, Scott | | | | | Joined: Jun 2005 Posts: 887 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 887 | I was looking for the same thing myself for a 1/2 ton. What I found at the junk yard was that the s-15 would work great in a truck if you use the hole in the roll pan for the crank handle. If you want the crank handle inside the suburban, look at the SUVs, especially the ford explorer, which has the crank lug on the floor inside the back of the suv.
Best of luck and let us know what you find out!
| | | | | Joined: Apr 2003 Posts: 608 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 608 | Gents,and Ladies of course,,, As an aside to this,What type of spare carrier was used on a 51 1/2 ton Subn? Is it the same as a pickup? Mine went missing when the Orig. owner put a tow hitch on the back,and i,d like to rig up something. Thanks + Regards, Steve Sr. | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | i believe 51 used the 45 degree mounted one from one frame rail to the other. i am putting a hidden hitch on my 49 so i want to mount the spare and make the hitch to clear the spare | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | sorry john not from inside the burb but a recent tip
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=008959;p=1#000010
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | thanks guys i went to pick a part after work today and picked one from a f***D windstar, the dodge carevan appeared to have plastic gears, i will update you when i install it | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Apr 2004 Posts: 4 Junior Member | | Junior Member Joined: Apr 2004 Posts: 4 | cable mounted spare tires are a wreak waiting to happen.Hope you have better luck than i did. | | |
