5 members (Donf, rfs56trk, DoubleB, BillCollins, Wally / Montana), 58 guests, and 3 robots.
Topics128,090
Posts1,056,022
Members48,430
I need a trailer hitch for my '62 Suburban. I want a decent, modern receiver-type hitch. Does anyone know if there is a place I can find a specific application for our '60-'66 trucks? Or am I going to have to find one that's the right width, and modify the mountings flanges that bolt to the chassis.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
I found a local shop whose specialty is truck accessories and welding. They custom made my hitch as they do many. It was 4 years ago but I remember that it was actually less than the cost of the 67-87 pre-made hitches that were available at the time. So I would look locally in one of your more populated areas for such a shop. BTW, it looks just like the shelf bought hitches. My only regret is that I didn't have them incorporate a spare tire carrier which they could have done.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
I purchased one from: www.lmctruck.com
Here is the link: http://www.lmctruck.com/icatalog/cbe/0045.asp
It was a direct bolt-on, however I did have to jockey the rear bumper brackets a bit, but everything fit and worked as designed.
Here is a picture of the receiver hitch installed on my '66 Chevy C10 lwb fleetside truck. It is hard to see, but it tucks up nice to the factory chrome bumper.
Receiver Hitch Cover
I hope this helps.
Tony
i got a class 4 one that was almost new off my cousin's 72 ford 1/2 truck, he didn't want it any more, is was a perfect fit for my 63 gmc k10. so if you look around and find one for that 70's vintage ford it should be the same for yours
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
Truck & Burb frames are different at the back, a truck hitch won't fit a burb. My next candidate for a swap is a hitch from a 73-91 suburban.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thanks for posting this question Brad. I had the same one actually. With all of the moving around we do, we need to put one on the 66 to tow the Rat Rod around. His F150 is going to be moving the 49.
4-5-6.. Thanks for the links! That looks really clean on the back.
SUPPORT OUR TROOPS
"Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan
1966 Fleetside SWB Webshots
I took one from a dodge caravan and cut it down in width to fit. the brackets that fasten to the frame rails had the perfect drop and angle.
The best price I've found for hitches is U-Haul. If you have a large U-Haul center near by they have receiver hitches to fit any vehicle including old Suburbans. I've have them install hitches on pickups, suburbans, and my 87 Jeep Grand Wagoner.
~Jim
The ones that fit the 63 thru 66 (like the one LMC offers) will not fit the 62. They have to be modified. You will spend more if you buy one and then have it modified. Unless you can do it yourself.
My Webshot Photos]
i vote for making it yourself. i made mine for my 64 c20 and do a lot of heavy towing. i bought channel that fits snug over frame and weld a heavy piece between them that you can weld your receiver tube to. it looks good and it will prob take more than the frame could handle. i bent the bumper brackets on my 66 pulling a heavy trailer and didn't want to do that again. you can also incorperate the saftey chain eyes and i put in two more tubes for a detachable towing sling cause my 64 is a wrecker. hr
