| | | Forums66 Topics128,088 Posts1,055,998 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 564 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 564 | I need a trailer hitch for my '62 Suburban. I want a decent, modern receiver-type hitch. Does anyone know if there is a place I can find a specific application for our '60-'66 trucks? Or am I going to have to find one that's the right width, and modify the mountings flanges that bolt to the chassis.
-Brad SOUTHERN FALL GABfestOctober 6 ~ Commerce, Georgia Details here!Never Pee on an Electric Fence. | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I found a local shop whose specialty is truck accessories and welding. They custom made my hitch as they do many. It was 4 years ago but I remember that it was actually less than the cost of the 67-87 pre-made hitches that were available at the time. So I would look locally in one of your more populated areas for such a shop. BTW, it looks just like the shelf bought hitches. My only regret is that I didn't have them incorporate a spare tire carrier which they could have done. | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I purchased one from: www.lmctruck.com Here is the link: http://www.lmctruck.com/icatalog/cbe/0045.asp It was a direct bolt-on, however I did have to jockey the rear bumper brackets a bit, but everything fit and worked as designed. Here is a picture of the receiver hitch installed on my '66 Chevy C10 lwb fleetside truck. It is hard to see, but it tucks up nice to the factory chrome bumper. Receiver Hitch Cover I hope this helps. Tony | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i got a class 4 one that was almost new off my cousin's 72 ford 1/2 truck, he didn't want it any more, is was a perfect fit for my 63 gmc k10. so if you look around and find one for that 70's vintage ford it should be the same for yours 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Truck & Burb frames are different at the back, a truck hitch won't fit a burb. My next candidate for a swap is a hitch from a 73-91 suburban. | | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | Thanks for posting this question Brad. I had the same one actually. With all of the moving around we do, we need to put one on the 66 to tow the Rat Rod around. His F150 is going to be moving the 49.
4-5-6.. Thanks for the links! That looks really clean on the back.
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | | Joined: Jan 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2005 Posts: 112 | I took one from a dodge caravan and cut it down in width to fit. the brackets that fasten to the frame rails had the perfect drop and angle. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | The best price I've found for hitches is U-Haul. If you have a large U-Haul center near by they have receiver hitches to fit any vehicle including old Suburbans. I've have them install hitches on pickups, suburbans, and my 87 Jeep Grand Wagoner.
~Jim
| | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | The ones that fit the 63 thru 66 (like the one LMC offers) will not fit the 62. They have to be modified. You will spend more if you buy one and then have it modified. Unless you can do it yourself. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i vote for making it yourself. i made mine for my 64 c20 and do a lot of heavy towing. i bought channel that fits snug over frame and weld a heavy piece between them that you can weld your receiver tube to. it looks good and it will prob take more than the frame could handle. i bent the bumper brackets on my 66 pulling a heavy trailer and didn't want to do that again. you can also incorperate the saftey chain eyes and i put in two more tubes for a detachable towing sling cause my 64 is a wrecker. hr | | |
