4 members (DadsFirstPickup, BC59, Lightholder's Dad, Otto Skorzeny), 127 guests, and 2 robots.
Topics128,135
Posts1,056,422
Members48,441
#234999 05/31/2007 4:46 AM
Y
Y Offline
I have rally wheels off 70-80's burb on my 53 3100 and I would like to find out if there are any other center caps that look better than the original "4x4" cap? I peeled the 4x4 decal off so theres a small hole in the center. I've seen some with mirrors or reflectors used to finish up the center cap . The original center caps are held on by 3 bolts. Any suggestions? Thanks, Phil
#235000 05/31/2007 5:59 PM
I saw some stick on decals on ebay that would fit,they looked pretty nice. Some had Chevy crossed flags on them. I think they were in the rallye wheel section.
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
#235001 06/01/2007 2:59 AM
JC Whitney sells the caps without the 4x4 logos.
Bill Burmeister
#235002 06/01/2007 3:08 AM
I put the smaller '88 and up 4X4 center caps on mine. They attach with screws from the back, but I drilled through the cap and attached them from the front with stainless steel screws. I took the plastic nut covers from the newer model and set them over my stock (little) lug nuts and set the center caps over them to pinch them against the wheel and then tightened down the stainless screw. I think they look better with the smaller cap,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#235003 06/01/2007 4:54 AM
I have the car "top hats" as theyre called, on my 6 lug blazer wheels. I made some clips to hold them on,,,,if youd like,ill send you a pic of what i did.
Marty
#235004 06/01/2007 5:16 AM
I just purchase a set of four Chevy bowtie Rally cap stickers on eBay for $12.00. They are the exact diameter and colors as the factory cap stickers. I have installed the factory 4x4 caps on a 2wd truck and put stainless steel inserts on the open caps from the back and installed the Bowtie stickers. They look great.
Bowtie Rally caps
Bowtie Stickers
JC Whitney Rally caps
#235005 06/01/2007 1:44 PM
Summit Racing Equip.has several different center caps for ralley wheels.I have the ones with 3 bar spinners on my 55,with chrome Corvette Ralley wheels.
#235006 06/02/2007 12:37 AM
This is what I'm running. http://rides.webshots.com/photo/2731701030092261295ROodmu
It's a center for a '94-'98 1/2 ton 4x4 with the screw on nut covers. How I did it is a little more involved than what others have done, as I'm running 1/2" studs instead of 7/17". I found the nuts, 7/8"hex with 1/2" threads, at a swap meet, just 1 vendor down from the caps. Unfortunatly, I didn't get the source of the nuts. It did require slight modification of the wheel, as the seat area for the nuts was a little small for that nut. I only had to re-machine the seat a little to increase the size, using a 60 degree 3 flute countersink bit. I know that y'all are thinking "What?!!, he replaced studs just to get the caps?!!". Actually, I'd already swapped out the studs, and had intended on a different wheel (6 lug 'Vette Ralley), but got a good deal on the Blazer Ralleys, the caps and nuts were just a lucky find. I had originally replaced the studs just simply because I've seen to many of the smaller studs break, namely due to overtightening, and I just prefer the extra strength of the 1/2" studs. Wasn't too hard to do, just cross referenced the knurl size from the OE to the thrad size I wanted. OK, I cheated. I have my own copies of both Napa and Dorman stud/nut catalogs, something the average 'Bolter won't have. But feel free to pick my brain if you need a stud/nut number, I'll look it up. Then you can watch the look on the face of the kid at the flaps when you just give him the part # instead of making him figure it out!
Bill Burmeister
#235007 06/03/2007 5:31 PM
Here is one more for you I had the centers of mine opened up to 4.25 inches, this allows you to use a number of different aftermarket centers. If you interested go to my webshots old truck page and look at rims 1 and rims 2.
http://rides.webshots.com/album/556364786koxhKA
