0 members (),
125
Mod | | | Forums66 Topics128,136 Posts1,056,425 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I have rally wheels off 70-80's burb on my 53 3100 and I would like to find out if there are any other center caps that look better than the original "4x4" cap? I peeled the 4x4 decal off so theres a small hole in the center. I've seen some with mirrors or reflectors used to finish up the center cap . The original center caps are held on by 3 bolts. Any suggestions? Thanks, Phil | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | I saw some stick on decals on ebay that would fit,they looked pretty nice. Some had Chevy crossed flags on them. I think they were in the rallye wheel section. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | JC Whitney sells the caps without the 4x4 logos.
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I put the smaller '88 and up 4X4 center caps on mine. They attach with screws from the back, but I drilled through the cap and attached them from the front with stainless steel screws. I took the plastic nut covers from the newer model and set them over my stock (little) lug nuts and set the center caps over them to pinch them against the wheel and then tightened down the stainless screw. I think they look better with the smaller cap, Scott | | | | | Joined: Nov 2001 Posts: 1,519 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,519 | I have the car "top hats" as theyre called, on my 6 lug blazer wheels. I made some clips to hold them on,,,,if youd like,ill send you a pic of what i did. Marty | | | | | Joined: Nov 2004 Posts: 1,552 Shop Shark | | Shop Shark Joined: Nov 2004 Posts: 1,552 | I just purchase a set of four Chevy bowtie Rally cap stickers on eBay for $12.00. They are the exact diameter and colors as the factory cap stickers. I have installed the factory 4x4 caps on a 2wd truck and put stainless steel inserts on the open caps from the back and installed the Bowtie stickers. They look great. Bowtie Rally caps Bowtie Stickers JC Whitney Rally caps | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Summit Racing Equip.has several different center caps for ralley wheels.I have the ones with 3 bar spinners on my 55,with chrome Corvette Ralley wheels. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | This is what I'm running. http://rides.webshots.com/photo/2731701030092261295ROodmu It's a center for a '94-'98 1/2 ton 4x4 with the screw on nut covers. How I did it is a little more involved than what others have done, as I'm running 1/2" studs instead of 7/17". I found the nuts, 7/8"hex with 1/2" threads, at a swap meet, just 1 vendor down from the caps. Unfortunatly, I didn't get the source of the nuts. It did require slight modification of the wheel, as the seat area for the nuts was a little small for that nut. I only had to re-machine the seat a little to increase the size, using a 60 degree 3 flute countersink bit. I know that y'all are thinking "What?!!, he replaced studs just to get the caps?!!". Actually, I'd already swapped out the studs, and had intended on a different wheel (6 lug 'Vette Ralley), but got a good deal on the Blazer Ralleys, the caps and nuts were just a lucky find. I had originally replaced the studs just simply because I've seen to many of the smaller studs break, namely due to overtightening, and I just prefer the extra strength of the 1/2" studs. Wasn't too hard to do, just cross referenced the knurl size from the OE to the thrad size I wanted. OK, I cheated. I have my own copies of both Napa and Dorman stud/nut catalogs, something the average 'Bolter won't have. But feel free to pick my brain if you need a stud/nut number, I'll look it up. Then you can watch the look on the face of the kid at the flaps when you just give him the part # instead of making him figure it out!
Bill Burmeister | | | | | Joined: May 2006 Posts: 29 New Guy | | New Guy Joined: May 2006 Posts: 29 | Here is one more for you I had the centers of mine opened up to 4.25 inches, this allows you to use a number of different aftermarket centers. If you interested go to my webshots old truck page and look at rims 1 and rims 2. http://rides.webshots.com/album/556364786koxhKA | | |
