1 members (Hotrod Lincoln), 72 guests, and 0 robots.
Topics128,049
Posts1,055,680
#234188 05/18/2007 12:09 AM
Apprentice
Apprentice
My 54 half-ton has an annoying habit of making a loud squeal whenever I turn sharply to the right. The kingpins were replaced recently, and everything has been adequately greased. Anyone have any ideas?
Thanks!
#234189 05/18/2007 1:08 AM
Wheel bearings?
1948 Chevy 1/2-Ton
"Tuesdays with Morris"
In the Legacy Gallery
Find it - Fix it - Drive it
#234190 05/18/2007 2:49 AM
Is it tire scrub or a metallic suspension/drivetrain noise?
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#234191 05/18/2007 4:24 AM
Stock wheels?
What size/type tires?
What air pressure in the tires?
#234192 05/18/2007 2:11 PM
Does it do it any particular type of pavement? Or all of the time? And if it does it all of the time, does it do it when turned even if the truck isn't rolling?
Bill Burmeister
#234193 05/18/2007 2:14 PM
dO YOU HAVE POWER STEERING if so check the belt, it will squeal when overloaded during a turn.
#234194 05/18/2007 5:12 PM
Apprentice
Apprentice
No power steering, so that's out. Wheel bearings were recently replaced. Sound is there when the wheels are spinning, during sharp right turns, on any type of pavement. (It is not the tires squealing against the road...) Almost sounds like rubber against metal, but I can't find any evidence of that. 15" wheels, and tires are not oversize.
#234195 05/18/2007 5:36 PM
Have you checked the bed to see if a stray pig has gotten in there? grin
1948 Chevy 1/2-Ton
#234196 05/18/2007 5:38 PM
take off the drums and look for signs of rubbing - sounds like those can be caused by side thrusting against poorly seating shoes, and there may be slight in/out movement of drums - might need a dab of brake grease where the shoes ride on the backing plate .... also check you got the spindle nut properly tightened
#234197 05/19/2007 2:53 AM
Don't turn SHARPLY to the right, make 3 left's. U joint's
#234198 05/19/2007 3:00 AM
Have you put the front of the truck up on jackstands so you can turn the wheels all the way to the right and spin the wheels? It would be nice if you can reproduce the sound in your garage.
