7 members (Gdads51, Gray_Ghost, Danielbolt, Wally / Montana, DadsFirstPickup, Leo, 1 invisible),
109
Mod | | | Forums66 Topics128,162 Posts1,056,953 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | When I bought my truck the booster/master cylinder had already been relocated under the cab. My brakes tend to tighten up when I drive my truck & I have no slack in my brake peddle. I have done everything but change the booster/master cylinder. All my local auto parts stores around here can do a darn thing with out the year and make of your vehicle. How can I match a master cylinder to the after market one on my truck??
Roger http://www.flickr.com/photos/45469713@N00/?saved=1
| | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Its been a long time since I adjusted the one on my truck.But there should be an adjustment on that unit to take care of that problem.If I remember right there should be a threaded rod coming out the front of the booster,that you adjust your pedal travel with.If yours has that try adjusting it one way or the other til you get some free travel in your brake pedal.Hope this helps. | | | | | Joined: Dec 2005 Posts: 101 Member | | Member Joined: Dec 2005 Posts: 101 | Thanks dale937 I will give it a try today!
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Mine tightens up some too, I've adjusted it so there's some pedal free play whenever it's hot. The master being under the floor and the heat generated by the drum brakes expand the components, making the pedal firm up. Scott | | |
