Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (‘37ChevyPU, NJC, Maybellene, Peggy M), 109 guests, and 3 robots.
Topics128,277
Posts1,058,453
Members48,490
#233105 05/02/2007 1:17 AM
I am looking into installing a RPM gauge into my 51. I am looking for something that looks orginal but new...something that matches the orginal gauges, and doesn't stick out like a sore thumb. What do you guys suggest?
1951 3100
http://community.webshots.com/user/HolcombRacing11
"Every child is an artist. The problem is how to remain an artist once he grows up."
Pablo Picasso
#233106 05/02/2007 1:46 AM
Holcomb,
Are you after a tachometer! I think the pickins will be slim if you are still running a 6 volt system. Stewart-Warner would probably be the oldest name to search for, but they wouldn't be in the '51 time frame or have the appearance of your gauges. These tach's were aftermarket items and weren't designed to match anything. If you are 'e-bay wise', that would be a great spot to get a feel for price and availability of a older tachometer. Good luck.
Stuart
#233107 05/02/2007 2:17 AM
Holcomb,
These guys have 6 Volt tachs that "look" old.
http://www.westach.com/
Paul
#233108 05/02/2007 2:26 AM
Sun has been around for a very long time, too, and they make a very nice looking tach.
As Stuart says, 6v is pretty slim pickings, but they can be found on ebay if you're patient. They usually run about $30-$80 for the transmitter and $20-$70 for the gauge, depending on the number of lobes and the voltage.
If you don't want to wait, give Williamson\'s a call and tell them what application you have and ask what they've got that'll work. Many bolters have used them and like their work. I'm thinking about sending my old Sun Brainbox to them for the solid-state conversion.
#233109 05/02/2007 2:26 AM
Sun tachometers of the day had a sending unit under the hood and the meter itself, in a bullet shaped chrome bullet, was usually mounted on the steering column. A friend had a 51 Merc with one. It looked good, but he wanted it to to help him shift at the optimum RPM. Unfortunately, it drew so much current from the points that the engine wouldn't rev very high and he had to disconnect it when he wanted to race.
#233110 05/02/2007 2:27 AM
WOW...so much for slim pickins! Great link Wisner955.
Stuart
#233111 05/02/2007 2:29 AM
ya neat link
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#233112 05/02/2007 2:41 AM
Huh.
I'm going to rethink using that sun gauge. That Westach unit will be half the price when it's all said and done.
#233113 05/02/2007 3:33 AM
Sorry about that I forgot to mention I rewired the entire truck with a gm 7 circuit harness. So now I am 12 Volt.
1951 3100
Pablo Picasso
#233114 05/02/2007 3:35 AM
Good website Wisner955...I will look into it.
1951 3100
Pablo Picasso
#233115 05/02/2007 4:58 AM
Didn't someone have a link for a company that can cut the center out of the instrument cluster and install a small tach?
