9 members (Gdads51, 52Carl, Stewart2, Gray_Ghost, Canadian Dump, KEVINSKI, Otto Skorzeny, Southerntruck, BC59),
184
Mod | | | Forums66 Topics128,165 Posts1,057,006 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Has anyone on this Forum converted their front brakes from Huck to Bendix? | | | | | Joined: Sep 2004 Posts: 168 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2004 Posts: 168 |
Your lack of preparation is not my emergency
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I have already read the Tech Tips, but on another Forum they claim it is not as simple as depicted in the Stovebolt Tech Tips. They refer to splitting the Huck hub away from the drums and using the original hubs. They also say that the center hole would have to be enlarged. This is why I am asking to hear from anyone who has actually done the conversion. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Not me.
~Jim
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have done this many times. The above link is correct, except it is the bottom holes in the spindles that need to be drilled to 1/2". If you use Bendex drums and hubs you will not need to mess around with any drum/hub work. Both styles use the same wheel bearings.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thank you Dave! What about changing the flex hoses, did you find that necessary? Mine are new. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The hoses have the same thread at the cylinder, so no problem.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Thanks I have and that is where the confusion comes in. He mentions splitting the drum/hub and re-using the Huck hubs. He also mentions enlarging the center hole. This is why I asked anyone who has done the upgrade exactly what method I use. | | | | | Joined: Sep 2006 Posts: 139 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 139 | since you have the complete front brake assys inc hubs, just mount to the front axle with new king pins, why worry about splitting them and using part of the huck set up?
1947 Studebaker M15 on 76 GMC one ton dually chassis with 454 4 spd 1953 Chevrolet 1/2 ton p/u 1957 Oldsmobile 88 2dr hardtop 1959 B130 International one ton dually | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | You must know what I have!!! Have considered that but my king pins are almost new. Good tip tho! | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | Olblu, the flex lines are different but yours will work. If I remember correctly the difference is where the hex part of the steel connection to the wheel cylinder is. On the hucks the line came straight out at a 90 and the hex part was right next to the thread to go into the cylinder. On the bendix the thread outlet at the wheel cylinder is more at a 45 and the hex part of the fitting was moved up about an inch from the threads to get it away from the backing plate. It is a matter of convenience for getting a wrench on them. I ran Huck type for a while and was able to get them off and on without a problem. If they were stuck, I believe it would be hard to get a tube wrench on them. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | | | |
