| | | Forums66 Topics128,078 Posts1,056,036 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 48 Junior Member | | Junior Member Joined: Dec 2006 Posts: 48 | I have just fixed the crank mechanism and the window goes open and closed but it leaves air spaces at the lower corners. The strap that connects the two halves together was missing so I made one. I dont think I made it beefy enough.
Can someome give me the dinensions of the original? How long, how thick, how tall and if you can, the angle its bent at. Is there only one on the inside? Top and bottom?
thanks as allways. | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | When you say the 2 straps that hold the halves together do you mean V blocks. I had to replace the ones on my 46 as they rust pretty bad from water that gets trapped in there, also there should be a locking mechanism on each side of the window frame. The V blocks are available from any of the Antigue Chev sites and aren't too expensive. Hope this helps, Bob T | | | | | Joined: Dec 2006 Posts: 48 Junior Member | | Junior Member Joined: Dec 2006 Posts: 48 | V blocks? That explains it. I assumed they were straps. I havnt seen the assembly so I didnt know what should be there. I dont have the side locking mechanisms either. If anyone has pictures I would love to see them. My email is [email protected]Thanks for the help. | | | | | Joined: Mar 2002 Posts: 553 Shop Shark | | Shop Shark Joined: Mar 2002 Posts: 553 | Originally posted by bobt: ... also there should be a locking mechanism on each side of the window frame.. Hope this helps, Bob T Locking mechanism? I don't have that. Do you have a picture of it? The reason that I ask is 'cause one of the bottom corners doesn't seal right. I think my frame is slightly tweaked at the bottom. I wonder if the lock would hold it closed better. Thanks, john. | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | Sorry, might have miss lead you, there V brackets and I had to replace my'n as one broke and I was going to fabricate one but realized it was made out of cast steel and machined, I guess thats what keeps them from bending out of shape. Bob T | | | | | Joined: Mar 2005 Posts: 284 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 284 | My 42 doesn't have any locks either. I don't think I have ever seen locks on the w/s on the 41-46 chevy. | | | | | Joined: Jul 2004 Posts: 2,987 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,987 | The '46 we had when I was growing up didn't have any, either. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | its been almost 30 years since I owned a 46 but as I remember its like my 37 which means the rubber seal that fits between the windshield frame and the body could be bad...or like my situation the wrong one!! | | | | | Joined: Dec 2006 Posts: 48 Junior Member | | Junior Member Joined: Dec 2006 Posts: 48 | Hey Steppinwood, You and I have the same problem. Leaking at the bottom corners and no side locks of any kind. I havnt got to the bottom of it yet, but I didnt think these had side locks with the crank in the center. I havnt come across any for sale on ebay either. Lots of other parts for the windshield, but no side locks. Hmmmmm.
Someone show us a picture, please. | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | The latches are very similar to a houshold window latch. I also forgot to mention this 46 is a Canadian model but I don't think that makes any difference. They lock the windshield closed from the inside. The swivel latch is mounted on the cab windshield post and hooks to the other part mounted on the windshield frame and are made out of brass. If I recall some of the military models had the same thing. Bob T | | | | | Joined: Dec 2006 Posts: 48 Junior Member | | Junior Member Joined: Dec 2006 Posts: 48 | I just looked on Brads site at the cab breakdown. There are no side brackets.
If you have them, someone added them. | | | | | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | WOW, Side latches??? Can you post some photos, my '41 has no sign of ever having them. Guess Chevy was counting on wind pressure at high speed to hold the windshield closed !!
Seriously I have heard of some of the replacement "V" connectors being on the wrong angle. Not sure what the correct angle is. I had one good one and one FUBAR so I fab'ed one from bar stock and simply copied the angle from the good one. I have not had the truck over 25MPH so am not sure if the windshield is sealed or not. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I would like to see those latches also. My windshield dosen't leak but It would be interesting to see what they look like. I think the key to sealing the windshield, as others have said, is to get the right angle. When I got my truck the windshield fit perfectly and the PO had put new glass in it, so I left it alone. No need to disturb a good fit. | | | | | Joined: Jul 2006 Posts: 187 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 187 | I had a 42' 1.5 ton military that had side brackets inside. You could lock the window in any position. I have never seen them on civilian trucks.
'36 Tall cab Chevy 1.5 ton, '36 Low cab Chevy 1.5 ton, '53 GMC 2 ton, '51 GMC 640 5 ton, '47 Dodge 2 ton, '42 GMC CCKW 353 6X6.
| | | | | Joined: Jan 2007 Posts: 50 Member | | Member Joined: Jan 2007 Posts: 50 | I saw a 46 fire truck with side "brackets " but the original center crank was removed. It looks like you can put the window out strait.? Both my 46's don't have any latch other than the center crank. :hammering: typing hurts my finger and brain.!
restoring a 1946 coe wrecker.
