3 members (Jon G, Otto Skorzeny, 1955 1 Series), 85 guests, and 2 robots.
Topics128,026
Posts1,055,399
Members48,422
#230791 04/01/2007 7:00 PM
Has anyone installed a peep mirror on the passenger side that actually adjusts correctly? I bought one and I can't adjust it correctly. I ended up breaking it trying to adjust it. Maybe there's a different made one that actually works.
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
#230792 04/01/2007 9:27 PM
At the risk of seeming ignorant, what the ____ is a peep mirror? Peep show??? Peeping Tom???
Confused... grin
~Jim
#230793 04/01/2007 9:48 PM
they are on the top of the door and used to peep at short shirts, i mean look for traffic.
#230794 04/01/2007 10:15 PM
check out this previous post,
click here
Redryder pix
My Hotrod
#230795 04/01/2007 10:17 PM
I like peep mirrors, they look nice!
By the way, peep mirrors are the little round mirrors that attached to the top of the door that are very small. I cant think of a better way to describe them.
1950 Chevy 3100 5 window "in progress"
1967 Chevelle 300
#230796 04/01/2007 10:28 PM
Thanks joker and all, at least I'm not the only one having problems with the passenger side mirror.I have a door mirror on the drivers side, but no mirror on the passenger side and didn't want to drill holes in the door,but may have to.
Joe
#230797 04/01/2007 11:37 PM
Ex Hall Monitor
Ex Hall Monitor
As noted in one of the follow-up posts, if you loosen the screw that holds the arm to the bracket you can get more adjustiment out of the mirror. I did this on mine and it works OK. There are also different arms configurations that might work for you if you can't make this one work.
#230798 04/02/2007 12:33 AM
I ordered some with a longer arm and hopefully they'll work. I did loosen the screw on the arm and still couldn't get them to adjust properly.
#230799 04/02/2007 2:18 AM
Cal55, on the pass. side mirror I installed a convex mirror to the existing face of my peep and the convex was almost the exact same size and had a ss frame. It helps alot when these people today pass you on the wrong side or if u r tring to get back in the right lane. Good Luck, Mike
#230800 04/02/2007 3:34 AM
On my '54, I installed a regular passenger side mirror from The Truck Shop (one with the largest size mirror) ... and, when I installed it, I had someone hold it in various positions until it was good -- then I drilled holes and mounted it.
I use it constantly -- it works great!
See Here
~~ Alan Horvath
1954 Chevy Pickup
Singing his praises in the
Passing Lane
#230801 04/02/2007 7:44 AM
I tried every thing to get it adjusted properly with no luck. I tried different positions on the door and adjusting the mirror different angles with nothing. I ended up bending the peep mirror arm and that seemed to fix the problem somewhat. Make sure you install locktight on the threading. I lost one of my mirrors going down the highway.
38 original
48 panel
59 stepside
46 in the back forty
#230802 04/02/2007 2:18 PM
Alan: Your work is great and exceeded only by your ability to explain it. What's the clear fingernail polish for?
~Jim
#230803 04/02/2007 4:57 PM
Forget the clear fingernail polish. Initially, someone told me to paint certain parts with it to keep it from rusting, but it didn't work.
If you look at my page *now* you'll see I updated that info -- I've since coated certain parts with GIBBS and haven't seen any rust since.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#230804 04/02/2007 5:06 PM
Thanks again guys for the tips, beautiful truck Alan, nice color. I'll see if the peep mirrors with a longer shaft work that I haven't received yet. If not, I'll put a stock mirror on that matches the drivers side. I just hate drilling holes in nice painted metal in fear I'll mess it up, but I really want a passenger side mirror for safety.
#230805 04/02/2007 7:52 PM
Joker - If you remember the mirrors you had trouble with you sold to me. The reason the one for the left side would not adjust is because they sent you two mirrors for the right side!!!!!!!! Only took me about 4 hours to figure that one out!!
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#230806 04/02/2007 8:34 PM
1 Offline
Im having the same problem...I got a 3" spot mirrors They look nice But thats about it, I tried everything.. everyway..Mine just didnt work out
did you see the ad truck on the cover of the newest LMC ? It looks nice, the mirrors look stock and it didnt have two differant arms ? But I couldnt find them in the catalog
keep us posted on the other set you got & how they worked out http://www.lmctruck.com/icatalog/ca/t.asp?page=0
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
#230807 04/02/2007 10:42 PM
Nice truck tabdoo16,I'll keep the list posted on the outcome. I bought them on ebay so I should have them by the weekend. I'll try to install it ASAP and let you know if it worked, I only need one for the passenger side, but they were sold as a pair.
Joe
#230808 04/03/2007 1:44 AM
A word of caution about putting peep mirrors on your truck: The PO of my truck had peep mirrors on ... and here's what happens over time:
The door *and* the door frame get messed up.
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#230809 04/03/2007 2:02 AM
They suck! They look kind of cool, but they are hard to see out of and make nasty marks on your doors. I bought a set and ended up returning them because I couldn't see a darn thing when I was driving around.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
#230810 04/03/2007 4:09 AM
I had 15" west coast mirrors on my 60 F*** truck. I could see a car on my right side from my drivers mirror.
~Jim
#230811 04/03/2007 5:12 AM
LOL! That's hilarious!
~~ Alan Horvath
1954 Chevy Pickup
Passing Lane
#230812 04/03/2007 5:28 AM
i think those are meant more for show trucks
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#230813 04/06/2007 12:23 AM
Just an update on the longer stem peep mirrors. I tried to mount the passenger side one today and it's about the same as the shorter one. So they didn't work either. I guess I'll be buying a stock mirror for the passenger side that matches the drivers side one, I just hate drilling holes. Another thing about the peep mirrors they did mar up the paint a little.
Joe
#230814 04/07/2007 5:05 PM
i had the same problem and i installed the glue on convex and it works great. ron
Ron, The Computer Greek
I love therefore I am.
1954 3100 Chevy truck
2017 Buick Encore
See more pix
#230815 04/07/2007 5:27 PM
Thanks Ron,
Maybe I'll try that, nice truck and MGA by the way.
Joe
