1 members (baldeagle),
142
Mod | | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Has anyone installed a peep mirror on the passenger side that actually adjusts correctly? I bought one and I can't adjust it correctly. I ended up breaking it trying to adjust it. Maybe there's a different made one that actually works. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | At the risk of seeming ignorant, what the ____ is a peep mirror? Peep show??? Peeping Tom??? Confused...
~Jim
| | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | they are on the top of the door and used to peep at short shirts, i mean look for traffic. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | check out this previous post, click here Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Nov 2006 Posts: 180 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 180 | I like peep mirrors, they look nice!
By the way, peep mirrors are the little round mirrors that attached to the top of the door that are very small. I cant think of a better way to describe them.
1950 Chevy 3100 5 window "in progress" 1967 Chevelle 300
| | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Thanks joker and all, at least I'm not the only one having problems with the passenger side mirror.I have a door mirror on the drivers side, but no mirror on the passenger side and didn't want to drill holes in the door,but may have to. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | As noted in one of the follow-up posts, if you loosen the screw that holds the arm to the bracket you can get more adjustiment out of the mirror. I did this on mine and it works OK. There are also different arms configurations that might work for you if you can't make this one work.
| | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | I ordered some with a longer arm and hopefully they'll work. I did loosen the screw on the arm and still couldn't get them to adjust properly.
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Mar 2005 Posts: 388 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 388 | Cal55, on the pass. side mirror I installed a convex mirror to the existing face of my peep and the convex was almost the exact same size and had a ss frame. It helps alot when these people today pass you on the wrong side or if u r tring to get back in the right lane. Good Luck, Mike | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | On my '54, I installed a regular passenger side mirror from The Truck Shop (one with the largest size mirror) ... and, when I installed it, I had someone hold it in various positions until it was good -- then I drilled holes and mounted it. I use it constantly -- it works great! See Here
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Oct 2005 Posts: 275 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 275 | I tried every thing to get it adjusted properly with no luck. I tried different positions on the door and adjusting the mirror different angles with nothing. I ended up bending the peep mirror arm and that seemed to fix the problem somewhat. Make sure you install locktight on the threading. I lost one of my mirrors going down the highway.
38 original 48 panel 59 stepside 46 in the back forty
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Alan: Your work is great and exceeded only by your ability to explain it. What's the clear fingernail polish for?
~Jim
| | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | Forget the clear fingernail polish. Initially, someone told me to paint certain parts with it to keep it from rusting, but it didn't work. If you look at my page *now* you'll see I updated that info -- I've since coated certain parts with GIBBS and haven't seen any rust since.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Thanks again guys for the tips, beautiful truck Alan, nice color. I'll see if the peep mirrors with a longer shaft work that I haven't received yet. If not, I'll put a stock mirror on that matches the drivers side. I just hate drilling holes in nice painted metal in fear I'll mess it up, but I really want a passenger side mirror for safety.
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Oct 2003 Posts: 297 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2003 Posts: 297 | Joker - If you remember the mirrors you had trouble with you sold to me. The reason the one for the left side would not adjust is because they sent you two mirrors for the right side!!!!!!!! Only took me about 4 hours to figure that one out!!
54 3100 w/62 235 "Yosemite Sam" Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
| | | | | Joined: Nov 2006 Posts: 677 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 677 | Im having the same problem...I got a 3" spot mirrors They look nice But thats about it, I tried everything.. everyway..Mine just didnt work out did you see the ad truck on the cover of the newest LMC ? It looks nice, the mirrors look stock and it didnt have two differant arms ? But I couldnt find them in the catalog keep us posted on the other set you got & how they worked out http://www.lmctruck.com/icatalog/ca/t.asp?page=0 Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs. 1951 3100 350 TBI Gallery Toddzilla... "$old" | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Nice truck tabdoo16,I'll keep the list posted on the outcome. I bought them on ebay so I should have them by the weekend. I'll try to install it ASAP and let you know if it worked, I only need one for the passenger side, but they were sold as a pair. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: May 2003 Posts: 1,271 Shop Shark | | Shop Shark Joined: May 2003 Posts: 1,271 | A word of caution about putting peep mirrors on your truck: The PO of my truck had peep mirrors on ... and here's what happens over time: picture The door *and* the door frame get messed up.
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Oct 2005 Posts: 738 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 738 | They suck! They look kind of cool, but they are hard to see out of and make nasty marks on your doors. I bought a set and ended up returning them because I couldn't see a darn thing when I was driving around.
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton My Machine | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | I had 15" west coast mirrors on my 60 F*** truck. I could see a car on my right side from my drivers mirror.
~Jim
~~ Alan Horvath 1954 Chevy PickupSinging his praises in thePassing Lane | | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | i think those are meant more for show trucks 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Just an update on the longer stem peep mirrors. I tried to mount the passenger side one today and it's about the same as the shorter one. So they didn't work either. I guess I'll be buying a stock mirror for the passenger side that matches the drivers side one, I just hate drilling holes. Another thing about the peep mirrors they did mar up the paint a little. Joe
54 Triumph TR2(rhd)needs total resto. 60 Apache 10 stepside shortbed 99 Excelsior Henderson | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i had the same problem and i installed the glue on convex and it works great. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Nov 2006 Posts: 213 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2006 Posts: 213 | Thanks Ron, Maybe I'll try that, nice truck and MGA by the way. Joe
