4 members (Joe H, Phak1, GMCJammer51, moparguy), 53 guests, and 0 robots.
Topics128,196
Posts1,057,398
Members48,471
i want to change to lower gearing, i want to keep the orginal axles on my 63 k10 they are 3.54's dana 44, but i want 4.10 or 4.56, i want to know if i can just change the ring and pinion, if so some of the sets of ring and pinions you see on ebay like the 4.56 that say its for a dana 44 fit?
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
You got the idea.
I recommend you buy the genuine Dana Spicer gear sets, they are consistently better quality than the rest.
If you have not done a gear swap on a Dana type axle before you may want to have a knowledgeable shop do it, or someone help that knows what to do. I am sure you can do it yourself if you read the manuals, but it is a little tricky to get things set just right.
I don't know about the Dana 44, but most Dana axles require a different carrier when switching from 4.10 or faster to 5.56 or faster. That is the most common "carrier brake" but sometimes it is a different ratio that the carrier changes, depending on the axle model.
If you go over that break, then it is a good time to buy a locker or two.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
ok, but i think the 3/4 tons were dana 44's and they had 4.56's
1964 gmc 4000
1973 gmc 6000
1994 chevy 1500
63 3/4T should be an Eaton, but will be 4.56, unless the Dana was an option.
Mike, Is your rear-end an 8-lug?
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
no it's a 6 lug 1/2 ton, but what i want to know the ring and pinion kits for a dana 44 you see on ebay, would they fit my dana 44 on my truck, thats all i want to change, to change the gearing, i don't want to up grade the axle, because it is original
1964 gmc 4000
1973 gmc 6000
1994 chevy 1500
