| | | Forums66 Topics128,277 Posts1,058,448 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 20 Junior Member | | Junior Member Joined: Mar 2007 Posts: 20 | Hey just wondering if anyone has relocated the gas tank to the back side of the truck between the frame rails. If you have what do you recomend and is it easy install thanks :rolleyes: | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Do a search. It's been discussed dozens of times | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | it has been discussed endlessly - I always recommend against it .... but there's always folks who won't listen Bill | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | There are numerous companies on the net that sell "universal gas tanks". do a search and you'll see. I'm installing one in the rear of my 46 with the filler centered at the rear with access through the wood bed. Bob T | | | | | | Anonymous Unregistered | | Anonymous Unregistered | IT IS THE RIGHT THING TO DO! | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i did and it has some addvantages other the lack of smell after filling. it adds weight to the back in snowy weather. yes i drive mine all year long that is what they are for. i am having it redone new body panels and paint and i still plan to use it as a truck was intended. i got my tank from fatfenderedstreet rods but there numerous ones out there. yes to the research on this site for a start. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Nov 2003 Posts: 285 Shop Shark | | Shop Shark Joined: Nov 2003 Posts: 285 | Did mine--very happy with the results! Mine also is filled thru the bed at rear center. I got my tank and fuel sender (0-30 OHM) from Yogi's Inc.. Run a little over $250 for the both of them 3 years ago. | | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | Added weight over the rear wheels is the first and only logical reason i've heard anyone give for relocating the gas tank.
On my '46 2 ton, I might end up going with one of those drum style frame mounted fuel tanks, but not for any other reason besides some fool gave me $250 for my original under seat tank.
A good condition, non leaking tank don't stink up the cab.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | One other advantage IMO is the added storage space behind the seat. For my purposes that was the driving issue. Better weight distribution is another. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i got a kit for my 64 a year ago. it was pretty easy but the filler neck was hard to locate it didn't come with it. i also got the plastic tank. i am going to try to see if one off a 90 something jeep cherokee i got a deal on will work on the 63 i am doing now. i haven't taken it off yet to see if it has a pump in the tank. i am going to try it and see how well it works i want the gauge to work too. | | | | | Joined: Oct 2006 Posts: 166 Shop Shark | | Shop Shark Joined: Oct 2006 Posts: 166 | Husband did mine a few weeks ago. I have 2 kids that I take everywhere so the smell and the added storage space were defnitely factors in my decision to do it. We got our kit off eBay for around 200. Worked great. He put the filler off to the side on the drivers side. On the 66 he had to cut out the spare tire bracket. It was easy for him because as he says "my wife lets me have the right tool for the job." hehe
SUPPORT OUR TROOPS "Some people wonder all their lives if they've made a difference. The Marines don't have that problem." -- Ronald Reagan 1966 Fleetside SWB Webshots | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Well as we are talking about making adjustments in gas tanks I have a question that has bothered me for years. Why in H___ do they put the gas filler tube on the passenger side when it is so much easier to fill on the driver's side? I'll buy the argument that the door key is on the passenger side for safety reasons but why the filler tube? Then I ask would it be possible to turn the tank 180 degrees and poke the filler tube out the driver's side.
~Jim
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | They did just that in the 60's!! Scott | | | | | Joined: Mar 2007 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2007 Posts: 69 | I did...I like the extra room in the cab and the install was easy. picture | | | | | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | To paraphrase the Nike phrase .... "Just Don't Do It!" | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I moved mine (63 K20) to the rear so I would have some place to mount real speakers. As I was welding up the 6" X 9" holes that some P.O. hacked into my doors, I thought that would be the best place for all of the stereo equipment. This truck will also have a class III receiver hitch surrounding it also. I didn't do it for the so-called "safety" of it, just to gain more interior room, Scott | | | | | Joined: Jan 2007 Posts: 50 Member | | Member Joined: Jan 2007 Posts: 50 | Filler on the right for "curb pump". That became habit for designers?? My 2 cents
restoring a 1946 coe wrecker.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Has anyone turned the tank 180 degrees and stuck the filler hose out the driver's side? I think that would be a great improvement and fun to watch other bolters do double takes when they see it.
~Jim
