3 members (Patharr, KEVINSKI, 1 invisible), 236 guests, and 2 robots.
Topics128,108
Posts1,056,230
Members48,436
i'm not switching, but is it true you can just reblt a 67-72 3/4 rear end in a 47-53 3/4? i heard this one time and was just wondering
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
I believe you can remove the inner assembly(pumpkin) and it is a direct bolt in. Im not sure but I think the preload on the pinion bearing is critical to prevent premature failure. Maybe others with more knowledge will chime in but while you're waiting, do a search for "pumpkin swap" at search link above and you'll get more info than you ever wanted to know.
Good luck,
Jeff
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
Junior Member
Junior Member
1 Offline
HEY GUYS I'M NEW TO THIS FORUM, I WAS JUST WONDERING IF ANYONE WOULD KNOW IF THERE IS A 5 ON 5 BOLT REAREND THAT WILL FIT INTO A 1963 CHEV C10 PICKUP WITH NO MODIFICATIONS.
Z
Z Offline
shorty,a 1971-72 c10 will bolt in if you modify the panard bar.
Junior Member
Junior Member
1 Offline
Thanks for your reply,now the search begins.
