4 members (55shaker, Forty9, Jon G, BillCollins), 203 guests, and 7 robots.
Topics128,080
Posts1,055,956
Members48,430
#228625 03/04/2007 6:56 PM
I have a 51 Chevy 3100 that I am restoring from the ground up. It has a 350 in it and I want to use the original (or original look) gauges for oil pressure, temp, fuel and ammeter. Surely somebody makes a conversion kit or new gauges that fit in place of the original that will hook up to the 350. Anybody have any ideas???? thanks slowgoer
54 Chevy 5 window - 46 Chevy 1/2 ton
#228626 03/04/2007 7:30 PM
All the venders have replacement guages to reach the 350 hook up. Just check out their catalogs under guages.
#228627 03/05/2007 11:05 PM
Riding in the Passing Lane
The oil is no problem. Just put the fitting in the outlet behind the dist. & put the tube in it. Like Elm says the specialty suppliers have temp gauges with longer tube & a special fitting.
1972 Chevy c10 Cheyenne Super
#228628 03/07/2007 6:29 AM
51 guages will work fine. Oil guage no problem, 350 will keep it pegged out. Can't remember if a 51 is a 15# but if so get a 53 30#. Amps are amps 6 or 12v so no problem there. Put a Runtz resistor on the "IGN" side of the gas guage, this is a must cause 12v will fry it. The long capillary tube temp guages are a little pricey but you can grind a flat spot on the left rear water runner on your intake, drill, tap, and screw in a temp bulb fitting. You can see a picture of this at http://www.msnusers.com/Evanscars
Click on "pictures" and then go to page 2 and it is picture S10-054.
Evan
#228629 03/07/2007 6:42 AM
check lmc truck or chevy duty
1949 Chevy 3600 Flatbed all orginal
1964 gmc 4000
1973 gmc 6000
2005 chevy duramax 4x4
1994 chevy 1500
Trucks are GM and Tractors are Orange
"I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton
#228630 03/07/2007 8:34 AM
You can get a 60 pound oil pressure gauge from a GMC or a '54 and change the face to match.
The temperature gauge will work too if you get an adaptor fitting for the bulb. It is a 3/8" gas flare fitting to a 1/2" NPT pipe fitting.
The ammeter will work just fine with an alternator too.
Paint & Body Shop moderator
