| | | Forums66 Topics128,052 Posts1,055,773 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2001 Posts: 111 | I have a 51 Chevy 3100 that I am restoring from the ground up. It has a 350 in it and I want to use the original (or original look) gauges for oil pressure, temp, fuel and ammeter. Surely somebody makes a conversion kit or new gauges that fit in place of the original that will hook up to the 350. Anybody have any ideas???? thanks slowgoer
54 Chevy 5 window - 46 Chevy 1/2 ton
| | | | | Joined: Aug 2002 Posts: 154 'Bolter | | 'Bolter Joined: Aug 2002 Posts: 154 | All the venders have replacement guages to reach the 350 hook up. Just check out their catalogs under guages. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The oil is no problem. Just put the fitting in the outlet behind the dist. & put the tube in it. Like Elm says the specialty suppliers have temp gauges with longer tube & a special fitting. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | 51 guages will work fine. Oil guage no problem, 350 will keep it pegged out. Can't remember if a 51 is a 15# but if so get a 53 30#. Amps are amps 6 or 12v so no problem there. Put a Runtz resistor on the "IGN" side of the gas guage, this is a must cause 12v will fry it. The long capillary tube temp guages are a little pricey but you can grind a flat spot on the left rear water runner on your intake, drill, tap, and screw in a temp bulb fitting. You can see a picture of this at http://www.msnusers.com/Evanscars Click on "pictures" and then go to page 2 and it is picture S10-054.
Evan
| | | | | Joined: Feb 2007 Posts: 513 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 513 | check lmc truck or chevy duty 1949 Chevy 3600 Flatbed all orginal 1964 gmc 4000 1973 gmc 6000 2005 chevy duramax 4x4 1994 chevy 1500 Trucks are GM and Tractors are Orange "I don't measure a man's success by how high he climbs but how high he bounces when he hits bottom." - General George S. Patton | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | You can get a 60 pound oil pressure gauge from a GMC or a '54 and change the face to match.
The temperature gauge will work too if you get an adaptor fitting for the bulb. It is a 3/8" gas flare fitting to a 1/2" NPT pipe fitting.
The ammeter will work just fine with an alternator too.
