6 members (Hotrod Lincoln, wilbur53, Wayne67vert, HandyAndy, TUTS 59, 1 invisible), 76 guests, and 2 robots.
Topics128,205
Posts1,057,430
Members48,471
what kinds of hiway speeds would i be looking at with my 51 1/2 ton 216 3 on the tree and factory 16in wheels? stock gear in closed drive shaft live in a small town she wont see much hiway but curious thanks
Mine will run 55-60 no problem with 7.00-16" rear tires. I'll get her up to 65 for short bursts, but the ol' 216's screaming pretty good by then.
Bob
This site will let you figure it out.
http://www.drivetraindirect.com/t_gear_calculator.htm
Just enter your tire outside diameter (measure with a tape measure), and your rear axle ratio. Then decide what is a safe max continuous engine rpm for driving, I would recommend keeping it at about 2,500 or less for your engine. 3,000 is defiantly too fast if you want your engine to last a while.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
My 53 has the same setup and I try to keep her under between 50-55. Over that and I dont think she'll last to much longer...
My 1953 Chevrolet
1947.1 Gallery
in my town i can put around at 50mph not a problem at all... ill keep her stock rebuild the 216 with updated bearings and leave the rearend gear alone... thanks guys
We run our 46 1/2 ton at 45 max on the highway.
Tempest
"Find Your Inner Truck"
Silly Boys! - Trucks are for Girls!
1945 2-ton
1946 3/4-ton
1951 Chevy 2-Ton
Redliners Auto Club
What\'z It
Snow Cruisers
The 216 in my 52 Chevy Deluxe died along time ago and (it is a car) so I guess it wouldn't count. ohwell
... so just get a 235, put it in a car, and you will go faster. grin
Cliff59
Deluxe \'52, Savoy \'54 Apache59
"She may not be the youngest girl at the ball, but she can still turn a head or two."
Indicated 50 mph,actual 60,750x16 recaps on rear.
I run mine no more than 45 max. The engine starts pushing a lot of rpm above that speed and I've thrown / bent rods and also have had a lot of serious bounces with the original suspension.
If it ain't broke, take it apart and figure out why!
39 Chevy in the Gallery
Photobucket Album
A lot of it depends on the rear gears and tires. Don't be afraid to let the old gal spin. I would recommend keeping her under 2500 rpm for extended travel With stock gears and tires the truck will run over 90, just don't hold it there for too long.
Extended running at high rpm can cause rod stretch, usually due to the babbit in the rod ends. More damage is caused by excessive lugging at low rpm, when the engine knocks.
If you're rebuilding, definitely go with the insert bearing rods. I would also do a rear gear swap, your engine will last longer running at lower rpm.
Fred
52 3600
69 C-10
