9 members (fonz8261, 55shaker, Guitplayer, Cletus1950, RoadsScholar, Otto Skorzeny, carbking, Greg_H, 1 invisible), 121 guests, and 1 robot.
Topics128,131
Posts1,056,721
Members48,454
#227302 02/15/2007 11:23 PM
When my uncle, a Chevy mechanic used to refer to our ol' stovebolts he just called it a "6". Everyone knew what that was, all the way up until the 80's a Chevy 6 only meant one thing, an inline 6-cylinder motor. Then, when the V-6's came along (I know about the early GMC's) I guess there had to be some way of differentiating between the two so it was called the I6. I just assumed that meant an Inline 6. Now, I see people reffering to them as L6. Where does that come from, and what does it mean?
#227303 02/15/2007 11:33 PM
inLine
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#227304 02/15/2007 11:34 PM
1 Offline
I am pretty sure it means longitudinal 6.
Sean
doing what you love is happiness
loving what you do is freedom
#227305 02/15/2007 11:44 PM
[QUOTE]Originally posted by 1969c10:
Sean
[/QUO
There is that $10 word,longitudinal ,I remember it now from way back there, a GM tech school instructor used it in the early-mid-'80s, they were still using them in trucks at the time,Brian
#227306 02/15/2007 11:51 PM
O.K., now, lets see, where did I put that dictionary?
#227307 02/15/2007 11:59 PM
As I recall, a flathead engine was called a 'L' head engine. If you have a L-6, it would be an old flahead Chrysler or Willys (4) or who ever, but not a Stovebolt or any other overhead valve engine.
The cylinder to valve relationship makes an inverted 'L'..hence the name!
Stuart
#227308 02/16/2007 2:03 AM
Come to think of it, I remember that L-6 designation for the old flathead sixes. So, is calling a 'bolt an L-6 a misnomer?
#227309 02/16/2007 2:59 AM
The 235 is referred to as an L-6 in the original shop manual. At least in 1960.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#227310 02/16/2007 3:07 AM
I was just at the Towe Auto Museum in Sacramento and I belive that the old Chryslers (I could be wrong about the make, but it wasn't any GM brand) had "L" heads, which seemed to refer to the cylinder valve relationship. I believe that this was not restricted to only 6 cylinder engines, but was also used in reference to straight 8's. Now I gotta' do some internet surfing to find out for sure, or I won't be able to sleep tonight. smile
58 Fleetside, 235, "The Old Buckin' Bronco"
#227311 02/16/2007 5:04 AM
I've always known them as 'straight' or 'inline' sixes.. altho Chrysler, just to be different had a 'slant' six.. which looked like a regular straight 6 kinda tilted to one side.
Buick had that straight 8 or 'fireball eight'.
#227312 02/16/2007 5:06 AM
"L" means linear as rather than V-shaped or opposed. Flat heads could be "L", "T" or the hybrid "F" configuration. The engine was not called by these letters without being followed by the word "head," ie. L head engine, T head engine or F head engine.
#227313 02/16/2007 5:50 AM
O.K. Here's what I found on the internet.
"L-head (flathead) refers to the pushrod valvetrain configuration in which the valves are placed in the engine block beside the pistons. The design was common on early engine designs, but has since fallen from use."
"The line of intakes along the side of the engine lead to the name L-head, due to the cylinders having the shape of an upside-down L. This configuration is also known as sidevalve, as the valves are located beside the cylinders."
"Although L-head inline 4 and 6 cylinder engines were frequently used for automobiles, tractors, etc., the best known L-head automotive engine is the early 20th century Ford V-8, which has both sets of valves (intake and exhaust) located on the inside of the "Vee," and which are all operated by a single camshaft located above the crankshaft. A serious concern is that the exhaust follows a more complicated path to leave the engine. This virtually guarantees that the engine will need an unusually large radiator to avoid overheating under sustained heavy use."
"Due to the heating and efficiency problems, L-head engines fell from high power uses such as aircraft engines fairly quickly, prior to World War I. They lived on for some time in the automotive world and were used in the World War II Jeep, for instance."
I also found that L-head type engines including V-8's were used in Cadillacs at least through 1929.
#227314 02/16/2007 6:18 AM
I love this site! It's like going back to school only the classes are fun! Thanks for all the input. Something bigmacdaddy said in this thread got me to looking at the old manuals in the tech tips section of this site. Sure enough, in the 1960 supplement, the 6 is referred to as an L-6. No explanation as to what that means, but there it is, right in the official Chevy manual. I like "linear". Anyone else?
#227315 02/16/2007 6:23 AM
Cadillacs V8s were L-heads until 1949.
#227316 02/16/2007 4:20 PM
i remember reading about what baldy said the L, T, and F valve configurations in a old auto manual years ago. best i remember the L head had become the most popular and was what was used most. this was a OLD manual.
#227317 02/17/2007 4:09 PM
1 Offline
I could go with linear
Sean
#227318 02/17/2007 6:12 PM
If the question was about an L7, we wouldn't have as hard a time figuring out the answer.
I don't know about anyone else, but that describes me describing my truck to anyone who isn't familiar with stovebolts or old trucks.
If it ain't broke, take it apart and figure out why!
39 Chevy in the Gallery
Photobucket Album
#227319 02/17/2007 6:23 PM
I'm voting for linear, its what my 63 and 66 manuals refer to it as. It also calls the L-4 diesel "linear."
#227320 02/17/2007 9:38 PM
Ter Offline
Here is how I have always thought it worked.
The term L head refers to the valve configuration and the shape of the combustion chamber in relation to the cylinder bore. L head, I think, refers the the shape of the chamber with the intake and exhaust on the same side... valves both on one side of the cylinder. Hence the vertical arm of the letter L is the cylinder bore and the lower arm of the letter is the shape of the chamber.
Flat head: ie old Ford V8s, early Chrysler 6 cylinders, Model A and T Ford 4 cylinders and many others, were L heads too.
A hemi V8 has a half ball shaped chamber, usually (early Chrylser) one central cam and very long exhaust rockers to activate the exhaust valves. A double overhead cam engine has the same chamber and valve relationship with no rockers but almost direct contact between the cam lobe and the valve stems. One cam for intake and one for exhaust.(Many European and Japanese engines)
An F head (I think early Jeep engines had these) had an overhead valve (intake I beleive) and an in block exhaust valve.
Please don't think I am presuming to be an expert.... this is just the way I understood it over many years and I could be very wrong.
Comments?
Ter
#227321 02/17/2007 9:56 PM
Ok,L,T or F head I understand.What about the Buick V-6 "nail head".Any Harley riders remember Pan Head or Shovel Head ?
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
#227322 02/18/2007 12:59 AM
Quote
That's what happened to your head if you didn't wear a helmet. eek
grin grin grin grin grin
#227323 02/18/2007 1:58 AM
What about the knuckle head? grin That was my fave.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#227324 02/18/2007 3:24 AM
1 Offline
Hey HevyHauler,
If we're talking Harleys then we forgot about pan heads and shovel heads. LOL
Sean
#227325 02/18/2007 6:02 PM
Ter Offline
Don't know anything about Harley's but I thought the Nail Head Buicks were older V8s of the 50's, 60's and the name was describing their small valves ie: like 'nails'??
Ter
#227326 02/18/2007 10:07 PM
Thanks Ter,Never knew why they called them "nail heads". I thought they were V6's not V8's, but don't remember.
Brendan M,I thought that was called "road rash" lol
Wanted Good Woman:
#227327 02/20/2007 4:16 AM
I always refer to them as a straight 6. gotta remember chrysler had a slant 6 in the 60's
"you can't fix stupid"
