3 members (klhansen, 3800GUY, 1 invisible),
63
Mod | | | Forums66 Topics128,153 Posts1,056,847 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | When my uncle, a Chevy mechanic used to refer to our ol' stovebolts he just called it a "6". Everyone knew what that was, all the way up until the 80's a Chevy 6 only meant one thing, an inline 6-cylinder motor. Then, when the V-6's came along (I know about the early GMC's) I guess there had to be some way of differentiating between the two so it was called the I6. I just assumed that meant an Inline 6. Now, I see people reffering to them as L6. Where does that come from, and what does it mean? | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | | | | | | Joined: Dec 2006 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 65 | I am pretty sure it means longitudinal 6.
Sean
doing what you love is happiness loving what you do is freedom
| | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | [QUOTE]Originally posted by 1969c10: I am pretty sure it means longitudinal 6.
Sean [/QUO There is that $10 word,longitudinal ,I remember it now from way back there, a GM tech school instructor used it in the early-mid-'80s, they were still using them in trucks at the time,Brian | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | O.K., now, lets see, where did I put that dictionary? | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | As I recall, a flathead engine was called a 'L' head engine. If you have a L-6, it would be an old flahead Chrysler or Willys (4) or who ever, but not a Stovebolt or any other overhead valve engine.
The cylinder to valve relationship makes an inverted 'L'..hence the name!
Stuart | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Come to think of it, I remember that L-6 designation for the old flathead sixes. So, is calling a 'bolt an L-6 a misnomer? | | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | The 235 is referred to as an L-6 in the original shop manual. At least in 1960. | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | I was just at the Towe Auto Museum in Sacramento and I belive that the old Chryslers (I could be wrong about the make, but it wasn't any GM brand) had "L" heads, which seemed to refer to the cylinder valve relationship. I believe that this was not restricted to only 6 cylinder engines, but was also used in reference to straight 8's. Now I gotta' do some internet surfing to find out for sure, or I won't be able to sleep tonight.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Jan 2005 Posts: 1,682 Extreme Gabster | | Extreme Gabster Joined: Jan 2005 Posts: 1,682 | I've always known them as 'straight' or 'inline' sixes.. altho Chrysler, just to be different had a 'slant' six.. which looked like a regular straight 6 kinda tilted to one side.
Buick had that straight 8 or 'fireball eight'.
| | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | "L" means linear as rather than V-shaped or opposed. Flat heads could be "L", "T" or the hybrid "F" configuration. The engine was not called by these letters without being followed by the word "head," ie. L head engine, T head engine or F head engine. | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | O.K. Here's what I found on the internet.
"L-head (flathead) refers to the pushrod valvetrain configuration in which the valves are placed in the engine block beside the pistons. The design was common on early engine designs, but has since fallen from use." "The line of intakes along the side of the engine lead to the name L-head, due to the cylinders having the shape of an upside-down L. This configuration is also known as sidevalve, as the valves are located beside the cylinders." "Although L-head inline 4 and 6 cylinder engines were frequently used for automobiles, tractors, etc., the best known L-head automotive engine is the early 20th century Ford V-8, which has both sets of valves (intake and exhaust) located on the inside of the "Vee," and which are all operated by a single camshaft located above the crankshaft. A serious concern is that the exhaust follows a more complicated path to leave the engine. This virtually guarantees that the engine will need an unusually large radiator to avoid overheating under sustained heavy use." "Due to the heating and efficiency problems, L-head engines fell from high power uses such as aircraft engines fairly quickly, prior to World War I. They lived on for some time in the automotive world and were used in the World War II Jeep, for instance." I also found that L-head type engines including V-8's were used in Cadillacs at least through 1929.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | I love this site! It's like going back to school only the classes are fun! Thanks for all the input. Something bigmacdaddy said in this thread got me to looking at the old manuals in the tech tips section of this site. Sure enough, in the 1960 supplement, the 6 is referred to as an L-6. No explanation as to what that means, but there it is, right in the official Chevy manual. I like "linear". Anyone else? | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | Cadillacs V8s were L-heads until 1949. | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i remember reading about what baldy said the L, T, and F valve configurations in a old auto manual years ago. best i remember the L head had become the most popular and was what was used most. this was a OLD manual. | | | | | Joined: Dec 2006 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 65 | I could go with linear
Sean
| | | | | Joined: Dec 2006 Posts: 184 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 184 | If the question was about an L7, we wouldn't have as hard a time figuring out the answer.
I don't know about anyone else, but that describes me describing my truck to anyone who isn't familiar with stovebolts or old trucks. | | | | | Joined: Nov 2005 Posts: 266 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 266 | I'm voting for linear, its what my 63 and 66 manuals refer to it as. It also calls the L-4 diesel "linear." | | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Here is how I have always thought it worked. The term L head refers to the valve configuration and the shape of the combustion chamber in relation to the cylinder bore. L head, I think, refers the the shape of the chamber with the intake and exhaust on the same side... valves both on one side of the cylinder. Hence the vertical arm of the letter L is the cylinder bore and the lower arm of the letter is the shape of the chamber. Flat head: ie old Ford V8s, early Chrysler 6 cylinders, Model A and T Ford 4 cylinders and many others, were L heads too.
A hemi V8 has a half ball shaped chamber, usually (early Chrylser) one central cam and very long exhaust rockers to activate the exhaust valves. A double overhead cam engine has the same chamber and valve relationship with no rockers but almost direct contact between the cam lobe and the valve stems. One cam for intake and one for exhaust.(Many European and Japanese engines) An F head (I think early Jeep engines had these) had an overhead valve (intake I beleive) and an in block exhaust valve. Please don't think I am presuming to be an expert.... this is just the way I understood it over many years and I could be very wrong. Comments? Ter | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Ok,L,T or F head I understand.What about the Buick V-6 "nail head".Any Harley riders remember Pan Head or Shovel Head ?
Wanted Good Woman: Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
| | | | | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | What about the knuckle head?  That was my fave. | | | | | Joined: Dec 2006 Posts: 65 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 65 | Hey HevyHauler,
If we're talking Harleys then we forgot about pan heads and shovel heads. LOL
Sean
| | | | | Joined: May 2002 Posts: 144 Shop Shark | | Shop Shark Joined: May 2002 Posts: 144 | Don't know anything about Harley's but I thought the Nail Head Buicks were older V8s of the 50's, 60's and the name was describing their small valves ie: like 'nails'?? Ter | | | | | Joined: Jan 2006 Posts: 586 Shop Shark | | Shop Shark Joined: Jan 2006 Posts: 586 | Thanks Ter,Never knew why they called them "nail heads". I thought they were V6's not V8's, but don't remember. Brendan M,I thought that was called "road rash" lol
| | | | | Joined: Jun 2006 Posts: 75 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 75 | I always refer to them as a straight 6. gotta remember chrysler had a slant 6 in the 60's
"you can't fix stupid"
