Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (BC59, TooMany2count, Otto Skorzeny), 116 guests, and 4 robots.
Topics128,277
Posts1,058,441
Members48,490
#226740 02/09/2007 3:40 AM
I finished painting the frame on my 53 3100, put the front axel and rearend back in, the engine and trans are out. I set the cab back on and it looks like a 4 wheel drive. the braces for the running boards are 16" off the floor. This can't be right.I don't think the engine and trans will bring it down that much. Does anyone have a bare frame to measure???? HELP :confused: :confused: :confused:
Popa Kents Body Shop
#226741 02/09/2007 4:28 AM
popa,
according to the GM engineering information for a 3104 in my 1951 restoration pack, the height of the top of the frame at the rear is 25 3/4".
1951 1 Ton Completed
#226742 02/09/2007 4:51 AM
25 3/4 inches to the top of the frame rail is
also confirmed by My info... Bill B
1952 Chevy 3104 Shortbed 5-window
Remember; Politicians and diapers both need to be changed
often, and for the same reason.....
#226743 02/09/2007 5:24 AM
Thanks for the info, please excuse my lack of knowledge on these trucks .I have a 3100. Is it the same as a 3104?At what place do you measure the hieght, front? center? rear ? What is a restoration pack ?? I have a factory assembly manual, but could not find any thing. Remember there is no engine or trans. THANKS FOR YOUR HELP
#226744 02/09/2007 5:59 AM
You made me curious. I just measured mine and the bottom of the running boards are 15" off the ground. Youd also be surprised how much those 6 cylinders weigh. It will sag down nice with the engine and everything else on it, hell it drops when I get in it...
My 1953 Chevrolet
1947.1 Gallery
#226745 02/10/2007 8:15 AM
Apprentice
Apprentice
1 Offline
This is what it looks like with no suspension
4" off the ground at the boards.
[img]http://i22.photobucket.com/albums/b350/stevehsd/truck034.jpg[/img]
#226746 02/10/2007 3:27 PM
Popa
Remember the fenders drop lower than the running boards and will drastically change the look and bring it down somewhat.
~Jim
#226747 02/10/2007 11:52 PM
51 chevy truck ,love it ,really nice........dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
#226748 02/11/2007 2:12 AM
popa, as far as I can tell from my paperwork, as far as the 3100 vs. 3104, 3100 is the series (1/2 ton) and the 3104 is the designation as far as body style. (p/u, panel, frame w/o box, etc.)
I may be wrong on this because I am still learning as I go. I am sure smarter people on here will correct me if I am.
