2 members (mo2cyl, Rusty Heaps),
59
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | I changed oil in my '59 235 and only got 4 1/2 quarts in (with filter) when it read full. I think I have the wrong dipstick as the pump wouldnt push consistant pressure till I put in another quart. Now it reads way over full but has steady 45 lbs pressure. Anyone have a picture and dimensions of the correct one????
'58 3600 350/4-sp/stepside/big window cab '59 3100 235/4-sp/stepside
| | | | | Joined: Oct 2006 Posts: 125 Member | | Member Joined: Oct 2006 Posts: 125 | dimensions of mine are 15 1/2" overall (bottom to the stop)...1 1/4' from bottom to add line, 5/8" more to the full line. The tube it goes in is 7" from base at block to top of tube...... anyone??
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Well now, ain't this interestin'? The tube on my '54 is only 6 1/2" long. All other measurements are the same as above except the distance between "add" and "full" is 1/2". | | | | | Joined: Apr 2005 Posts: 187 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 187 | You might want to check your pickup tube on your oil pump.I had one come off and my oil pressure acted just like yours. Floyd
_____________ Floyd If we choose being kind over being right,we will be right every time. Knowledge is a poor substitute for experience. Remember what is precious to another, may not be to you, but it is precious nonetheless. 1948 Chevy 2-Ton | | | | | Joined: Apr 2006 Posts: 236 'Bolter | | 'Bolter Joined: Apr 2006 Posts: 236 | On my 58, the tube is 6 3/4 inches long (though it could have been 7 as I didn't lean all the way into the engine bay to read it), the dipstick is 16 inches from tip to stop, the low mark is 1 1/4 inces from the tip, and the full mark is 5/8 inches from the low mark.
58 Fleetside, 235, "The Old Buckin' Bronco"
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I agree with tntrucknut. You should have full and steady pressure with only a couple of quarts. You're sucking air somewhere below the overfull level (oilpump pick-up tube), Scott | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | yep pull the pan and have a look then see if your stick reaches the pan | | |
