7 members (fonz8261, Rexville48, 1955 1 Series, Peggy M, mk72, Shardean, 55shaker), 60 guests, and 2 robots.
Topics128,022
Posts1,055,387
Members48,422
#226424 02/04/2007 11:19 PM
I changed oil in my '59 235 and only got 4 1/2 quarts in (with filter) when it read full. I think I have the wrong dipstick as the pump wouldnt push consistant pressure till I put in another quart. Now it reads way over full but has steady 45 lbs pressure. Anyone have a picture and dimensions of the correct one????
'58 3600 350/4-sp/stepside/big window cab
'59 3100 235/4-sp/stepside
#226425 02/05/2007 12:09 AM
dimensions of mine are 15 1/2" overall (bottom to the stop)...1 1/4' from bottom to add line, 5/8" more to the full line. The tube it goes in is 7" from base at block to top of tube......
anyone??
#226426 02/05/2007 12:32 AM
Well now, ain't this interestin'? The tube on my '54 is only 6 1/2" long. All other measurements are the same as above except the distance between "add" and "full" is 1/2".
#226427 02/05/2007 12:59 AM
You might want to check your pickup tube on your oil pump.I had one come off and my oil pressure acted just like yours.
Floyd
_____________
Floyd
If we choose being kind over being right,we will
be right every time.
Knowledge is a poor substitute for experience.
Remember what is precious to another, may not be to you, but it
is precious nonetheless.
1948 Chevy 2-Ton
#226428 02/06/2007 1:43 AM
On my 58, the tube is 6 3/4 inches long (though it could have been 7 as I didn't lean all the way into the engine bay to read it), the dipstick is 16 inches from tip to stop, the low mark is 1 1/4 inces from the tip, and the full mark is 5/8 inches from the low mark.
58 Fleetside, 235, "The Old Buckin' Bronco"
#226429 02/06/2007 4:33 AM
I agree with tntrucknut. You should have full and steady pressure with only a couple of quarts. You're sucking air somewhere below the overfull level (oilpump pick-up tube),
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#226430 02/06/2007 8:43 AM
yep pull the pan and have a look then see if your stick reaches the pan
