0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#22547 01/28/2005 9:24 PM | Joined: Jan 2005 Posts: 16 Junior Member | | Junior Member Joined: Jan 2005 Posts: 16 | Hey guys, What would you consider to be the best method to upgrade the ignition system on my 1960 235? Thanks | | |
#22548 01/28/2005 10:59 PM | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I've heard nothing but good about the Pertronix system although I haven't used it personally. Google their website for info.
Welcome to the Stovebolt pages. The more Texans, the better. | | |
#22549 01/29/2005 12:47 AM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Langdon's Stovebolt Engine Co. also sells a complete distributor that allows you to keep the original look. Pertronix is either hated or loved depending on who you talk to but I've never had one so I don't know anything except te originals and the Stovebolt unit which I like. www.stoveboltengineco.com | | |
#22550 01/29/2005 1:07 AM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | I highly recommend Mr. Langdon's mini HEI dizzy. I just bought one a couple of weeks ago and WOW. What a difference. The 235 idles smoother and seems to have a little more mid-range ummph. I wish I had done it years ago. It is an easy swap, and looks original (to the untrained eye).
-Tim '51 Chevy 3104 w/'56 235, 848 Head, HEI Dizzy, Corvette Cam, Split Manifold and Dual Carter YF's
#22551 01/29/2005 1:10 AM | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | i have the pertronix in my 54-3100/235 2 yrs no problem. putting one my 60 mga soon. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
#22552 01/29/2005 11:05 PM | Joined: Jan 2005 Posts: 16 Junior Member | | Junior Member Joined: Jan 2005 Posts: 16 | Fab51, I remember reading an old post about something wrong with the dist shafts on those mini hei's from Langdon. They were not identical to the original or something... Did you have any problem with the installation? | | |
#22553 01/30/2005 12:02 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | There have been a few cases of the mini HEI putting excessive pressure on the oil pump causing lots of ground up metal in the oiling system.Sometime the blocks just arent machined perfectly cause the original distributer has sort of a floating arangement.If you have a block that slightly less than it should be and you snug down that Langdon style HEI, you may have problems.Never intall a modified part without first cafefully checking out any clearance issues.And never believe a guy on the phone who tells you otherwise. I installed Pertronx units on two of my 261 powered trucks last year.One failed after a month while I was 80 miles from home towing a trailer,not good,Pertronis sent me a replacement under warranty.The other works perfectly ,took several long trips and daily driving with no problems. Do they out perform points? My trucks had good distributers with properly adjusted points,a slight idle smoothness improvement, but overall I can't notice any difference. | | |
#22554 01/30/2005 5:40 AM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I fitted a pertronix to my '40 a year or so ago ,, perfect performance all the time , I think it was money well spent. | | |
#22555 01/30/2005 7:28 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Our local parts chain stopped selling Pertronix because of problems and returns. As was mentioned above, you either love them or hate them. I wanted to do mine and someone stated that if it breaks down in the middle of nowhere you are stuck. Whereas with points you can get it going. I think there are other manufacturers of these modules as well like Crane. | | |
#22556 01/30/2005 10:33 PM | Joined: Jan 2005 Posts: 16 Junior Member | | Junior Member Joined: Jan 2005 Posts: 16 | I would rather do the complete dist changout with a HEI model if I could. Does anyone else do a complete HEI dist for the old 235 besides Langdon? | | |
#22557 01/30/2005 11:17 PM | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | oldblu, I carry a plastic ziploc bag in my glovebox. In it are the points, condensor, screwdriver, a set of feelers, and a piece of paper with the specs. If my Pertronix does let me down, I can be up and running in under fifteen minutes. Just a thought.....  | | |
#22558 01/30/2005 11:35 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | If you have to carry a points set up in case the Pertronix fails...........Do you carry a spare fuel pump? Crabjw,I used to convert the big cap HEI's from 75 and up 250 engines for use 235's or GMC's.Did a bunch,but don't anymore,if ya want, email me, I can describe the modifications.Very easy,a file and hacksaw will do it. | | |
#22559 01/31/2005 1:11 AM | Joined: Apr 2004 Posts: 375 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2004 Posts: 375 | Where's the possible clearance issue on the Langdon HEI? I bought one and would like to check it out before installation. | | |
#22560 01/31/2005 2:08 AM | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | [QUOTE] ...........Do you carry a spare fuel pump? Actually, yes, just not in the glovebox however.  | | |
#22561 01/31/2005 12:46 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | Jerry,the original distributer is held down by a pinch clamp,a flimsy thing.When the engine is running,the cam gear pulls the distributor shaft downward,but it is somewhat free to rise up on it's own,never an excessive downward force. The Mini still has the locating collar like a small block or later 6 distributer? If so,when you clamp it down,the shaft and gear may be forced down by the bolt.This will grind up the oil pump,not good.Just make sure when installed,the it slips in easy,goes all the way down and the shaft(not the auto advance device)has a touch of play upward. The machining tolerances can stack up wrong, be sure to check it out. | | |
#22562 01/31/2005 2:50 PM | Joined: Jan 2005 Posts: 310 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 310 | Mr Langdon's instructions don't address this problem specifically, but he does mention that the shaft should slip in easily and once in place should have a certain amount of up and down free travel. I haven't had any problems yet, but I've only had it a couple of weeks. Sounds like something to keep an eye on.
#22563 02/01/2005 1:16 AM | Joined: Aug 2000 Posts: 197 Member | | Member Joined: Aug 2000 Posts: 197 | Some time ago, it was discussed that a bushing would be nice to increase the diameter of the mini hei disty shaft to the 0.49 of the stock disty. I have been in the process of converting a mini hei for an reo engine and found that Small Parts has thin wall tubing that is 0.5 OD and would work for a bushing.
Jason
#22564 02/02/2005 4:34 AM | Joined: Jun 2004 Posts: 40 Junior Member | | Junior Member Joined: Jun 2004 Posts: 40 | I have a 261, but it is the same distributor as the 235. Jim carter has some chevy hei distributors that I have in. It is basically a Chevy s10 that has been reworked to fit the 235. Mine fit with no problems. I am very happy with it. If you are looking I think it iw worth a look.
Ted Wilson
#22565 02/05/2005 6:28 AM | Joined: May 2004 Posts: 62 Member | | Member Joined: May 2004 Posts: 62 | We have been running a Mallory Electonic distributor for several years and never a miss! Available from Patrick's and I believe Summit Racing can get them.
47 Fleetmaster, Hotrod 6, 5 Speed 50 Sedan Delivery, 327, 5 Speed
