4 members (Hotrod Lincoln, Ranger, Peggy M, carbking), 44 guests, and 2 robots.
Topics128,035
Posts1,055,443
Members48,422
#223349 01/03/2007 10:09 PM
Junior Member
Junior Member
yea, I'm sitll new but I have a question.
What's the differences in front fenders between 1947-2 and 1954? My 47 has a right fender that's all mangled and dinged up and was curious so I could get a correct replacement. Seems like the wheel cutout areas are different. Some big, some small.
Thanks for your time.
#223350 01/03/2007 11:08 PM
Kelly Wood,
To my knowledge, the fender will fit, but because the '54 uses a different grill, it will have a section near the parking light (54) that looks strange.
Stuart
I
I Offline
yep the fenders will fit the truck, but theres a sunken in place that will show. Also there are bolt holes in the front of it for the 54's grill and parking lite assembly
Jeff
1947 Chevy 6400 2-ton
1953 3/4-ton
It was fun while it lasted
47 2nd series to 53 Chevrolet 1/2 ton to 1 ton pick-up and panel/suburban (front) fenders should interchange,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Quote
Scott
Can I add a little to that?
GMC fenders have a hole for the parking lights.
A '54 or '55 1st will have an indentation for the parking lights.
Trucks larger than 1-ton do have a larger wheel opening. If you're looking at a fender with a larger opening, its probably also longer and wider to fit a bigger truck.
