| | | Forums66 Topics128,014 Posts1,055,330 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | With this being my first stovebolt (of many, hopefully), I'm a little uncertain of the bed strength. I already know that I need to rebuild my bed practically from all new parts, but I'm still worried. Being a woodworker, I know that wood, even 3/4" has structural weak points. I plan on being able to carry my Harley in the back if need be. Will the weight of the motorcycle in the small areas of the wheels be too much for the slats? I'd really, REALLY hate to hit a hard unseen bump come out of it fine only to find my motorcycle up to it's hubs through the bed!!!
If practice makes perfect, and nobody is perfect, then what's the point of practicing???
| | | | | Joined: Dec 2003 Posts: 975 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 975 | Dearth,
I am guessing your bed will have no problem with a Harley. The steel cross members are close enough together to give the pine, oak or wood of your choice the strength it needs. If you are going stock, the bed strips and the fender washers underneath give added linear strength.
My truck had two huge irrigation pumps in the back when I picked it up. Owner said "I hope you enjoy your pumps". They weighed in at about 250 to 300 a piece. The old bed that was 60 odd years old held them just fine. I figure the new bed will work even better.
Your Harley oughta be safe...
I would love a 42 Harley for the back of my 46! | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | If your bedboards are in good shape I would think it would be fine. If it worries you that much place a 2'x2' piece of plywood under each wheel. Or just throw a whole sheet in there. | | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | Sounds good! My bedwood, cross sills and everything else are brand-spanking new, so I guess I shouldn't have any problems then. I am using the oak, too, so that should be rigid enough. I definitely agree with the old Harley, too! I only have so much money tho'...
