2 members (Woodcmiami, baldeagle), 93 guests, and 10 robots.
Topics128,014
Posts1,055,324
Members48,419
#222769 12/27/2006 9:02 PM
Apprentice
Apprentice
With this being my first stovebolt (of many, hopefully), I'm a little uncertain of the bed strength. I already know that I need to rebuild my bed practically from all new parts, but I'm still worried. Being a woodworker, I know that wood, even 3/4" has structural weak points. I plan on being able to carry my Harley in the back if need be. Will the weight of the motorcycle in the small areas of the wheels be too much for the slats? I'd really, REALLY hate to hit a hard unseen bump come out of it fine only to find my motorcycle up to it's hubs through the bed!!! eek
If practice makes perfect, and nobody is perfect, then what's the point of practicing???
#222770 12/27/2006 9:39 PM
Dearth,
I am guessing your bed will have no problem with a Harley. The steel cross members are close enough together to give the pine, oak or wood of your choice the strength it needs. If you are going stock, the bed strips and the fender washers underneath give added linear strength.
My truck had two huge irrigation pumps in the back when I picked it up. Owner said "I hope you enjoy your pumps". They weighed in at about 250 to 300 a piece. The old bed that was 60 odd years old held them just fine. I figure the new bed will work even better.
Your Harley oughta be safe...
I would love a 42 Harley for the back of my 46!
#222771 12/27/2006 9:43 PM
If your bedboards are in good shape I would think it would be fine. If it worries you that much place a 2'x2' piece of plywood under each wheel. Or just throw a whole sheet in there.
#222772 12/28/2006 4:24 PM
Apprentice
Apprentice
Sounds good! My bedwood, cross sills and everything else are brand-spanking new, so I guess I shouldn't have any problems then. I am using the oak, too, so that should be rigid enough.
I definitely agree with the old Harley, too! I only have so much money tho'... grin
