7 members (MRMEROTH11, TUTS 59, Barney1951, Gray_Ghost, Wickedbass, JW51, walter74),
96
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,068 Posts1,055,880 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | whats the easiest way to tell what gear ratio is in a rear end. i saw someone do it wiith the cover off and counted the ring gears and then the pinion,did some quick math and within a minute or so,,"its a 3:73". theres gotta be a simple way to do it.............. thanks all,Marty | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | compare driveshaft revs to wheel when jacked up. | | | | | Joined: Mar 2006 Posts: 262 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 262 | The Camaro rearend I put in my '49 had the numbers stamped on the edge of the ring gear. Didn't realize that's what the numbers were until I counted the teeth!
My truck: She may not be the prettiest girl at the dance, but she's all mine!
| | | | | Joined: Nov 2006 Posts: 35 Apprentice | | Apprentice Joined: Nov 2006 Posts: 35 | gazim,
So are you saying that in the previous example of 3:73, there would be three rotations of the wheel to 73 rotations of the driveshaft? Or vise versa? Just curious how you get the ratio that way and not understanding...
What can I say? I'm dense.
If practice makes perfect, and nobody is perfect, then what's the point of practicing???
| | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Nope. The driveshaft would turn 3 3/4 times to one turn of the wheel. The ratio is 3.73 - 1 (almost 3.75 - 1). If you counted the teeth on the crown gear (the big one) and divided that number by the number of teeth on the pinion gear, you'd have your differential gear ratio of 3.73 - 1. Hope that helps. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | You can count the driveline rotations just as the post above stated. You have to have both wheels off the ground if its a positrac. If its just a open differential where only one wheel drives or spins, then you have to jack only one side up. Mark the tire and ground or fender with chalk so you can tell one full revolution. Mark the driveshaft the same way. Turn the driveshaft till the tire goes (two) full turns and count the driveshaft turns. Since there are side gears in the differential and one wheel is heald solid on the ground the wheel rotating will go twice as far with each turn of the driveshaft. You still count the the two turns of the tire as one, so yes to your question, 1 tire to 3.73 of driveshaft will be a 3.73 to 1 gear ratio. 4.11 will be, one tire to 4.11 driveshaft. There are a lot of choices in gears ratios depending on what axle you have, 4.56, 5.13, 3.08, 3.42, 3.55, 2.76, etc.......
Of course none of this will count on a inclosed torque tube set up! Joe | | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | As much a hassle as it sounds,you can do the same trick on a torque tube set up,only you pull the spark plugs,put the transmission in HIGH gear,and crank the engine until the wheel turns a full turn,and count how many full rotations the engine makes. Needless to say,this one's a ton easier with two people. I've also used a mirror propped up so I could see the mark on the wheel,and cranked the engine with a big ratchet and socket. Speed | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | thanks Hotshoe...thats the way he did it! exactly what i was trying to confirm. | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Dec 2006 Posts: 22 Apprentice | | Apprentice Joined: Dec 2006 Posts: 22 | Hotshoe is correct. The only way to get the precise ratio is to count the teeth and divide.
Fleetside Bob
