1 members (Hotrod Lincoln),
72
0
Mod | | | Forums66 Topics128,049 Posts1,055,680 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2004 Posts: 36 Apprentice | | Apprentice Joined: Aug 2004 Posts: 36 | I just installed a 4 speed trans into my 1953 chevy 3100 and I must say it is a pleasuer to drive. I have been dealing with a junk 3 speed three on the tree that kept jumping out of thhird gear. My only problem is now is there isa noise coming from the frame somewhere, I hear it when I hold the clutch in for a long period of time.can't tell where it's coming fromhowever I love the feel of the shifter. | | | | | Joined: Nov 1995 Posts: 5,716 62401 | | 62401 Joined: Nov 1995 Posts: 5,716 | Hey lock -- Is it an SM420? And where in Maryland are you?
That noise could be a number of things -- did you have to alter the driveshaft? Could it be out of balance? Is your carrier bearing secure? U-Joints, etc?
And did you secure the nut on the output yoke?
Hope any of this helps, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | If you're hearing it when you hold the clutch, it's probably the throw out bearing. Did you install a new one when you put in the 4 speed? An old timer told me best thing to do with a new throw out bearing is to boil it in STP on top the stove. I've tried it and have never had trouble with them. | | | | | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | You really shouldn't have your clutch down for long periods. Just put it in neutral to prolong TO bearing life. | | | | | Joined: Aug 2004 Posts: 36 Apprentice | | Apprentice Joined: Aug 2004 Posts: 36 | I boy I blew it, The sound I heard was the muffler hitting aganst the frame, I moved it over by loosening the clamp and now everything is quiet, I did not put a new throw out bearing in when we changed over to 4 speed however evrything was new anyway from all the trouble with the three speed, with the kit from patrick's you dod not have to alter the drive shaft. | | | | | Joined: Sep 2005 Posts: 191 Shop Shark | | Shop Shark Joined: Sep 2005 Posts: 191 | Glad you found the problem and it was simple to fix.  | | |
