4 members (MikeStone1953, Hawkman, Peggy M, Lostbuthaulinass), 68 guests, and 2 robots.
Topics128,057
Posts1,055,810
#220352 11/24/2006 12:18 PM
Apprentice
Apprentice
I just installed a 4 speed trans into my 1953 chevy 3100 and I must say it is a pleasuer to drive. I have been dealing with a junk 3 speed three on the tree that kept jumping out of thhird gear. My only problem is now is there isa noise coming from the frame somewhere, I hear it when I hold the clutch in for a long period of time.can't tell where it's coming fromhowever I love the feel of the shifter.
#220353 11/24/2006 12:49 PM
62401
Hey lock -- Is it an SM420? And where in Maryland are you?
That noise could be a number of things -- did you have to alter the driveshaft? Could it be out of balance? Is your carrier bearing secure? U-Joints, etc?
And did you secure the nut on the output yoke?
Hope any of this helps,
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
#220354 11/24/2006 11:25 PM
If you're hearing it when you hold the clutch, it's probably the throw out bearing. Did you install a new one when you put in the 4 speed? An old timer told me best thing to do with a new throw out bearing is to boil it in STP on top the stove. I've tried it and have never had trouble with them.
#220355 11/25/2006 4:41 AM
You really shouldn't have your clutch down for long periods. Just put it in neutral to prolong TO bearing life.
#220356 12/04/2006 2:42 PM
Apprentice
Apprentice
I boy I blew it, The sound I heard was the muffler hitting aganst the frame, I moved it over by loosening the clamp and now everything is quiet, I did not put a new throw out bearing in when we changed over to 4 speed however evrything was new anyway from all the trouble with the three speed, with the kit from patrick's you dod not have to alter the drive shaft.
#220357 12/04/2006 2:59 PM
Glad you found the problem and it was simple to fix. wink
