5 members (Peggy M, manymiles, Hanks custodian, Gdads51, mick53), 100 guests, and 3 robots.
Topics128,151
Posts1,056,989
Members48,460
Kicking around some ideas. The auto trans available in the early '60s was the 2spd PowerGlide.
How do I put a Turbo 350 or Turbo 400 into my '62 Chevy truck, and use a stock-style steering column, with the key on the dash?
Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
The old PG column works fine,,2nd is "L" & low is off the dial, but "PRND" all line up. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
At one time i had a 58 chevy 3/4 ton with a 396 and 400 turbo. I made my own column shifter.
I used some small diameter round bar with a bend at the top end, welded an arm at the bottom for the shifter linkage rod. It was real fast and simple, although not very pretty. With a little junk yard looking and a Saturday fabricating, a real nice shifter could be made.
Quote
My brother did one just like that some years ago. It worked just fine.
Can you go into L1 with it that way? Or are you limited to going into 2nd? I'm wondering, because it'd be nice in some instances to put it in 1st and keep it there.
I've got a stock Auto trans column, but for some reason the gear shift indicator was missing, and there are no mounting holes for it on the collar. It also was missing the shifter linkage rods when I got it.
It WAS an auto trans truck, though: well optioned, had no clutch pedal on the assembly, and the reservoir was blocked off.
Brad
Details here!
Yeah, it goes into low, it's just off the dial on the column,,Brian
I used a column from a 70 C10 in my 63. A little modification was necessary, but not hard,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I will be wondering about this too, but with my 350th I want to keep the shifter on the floor, the column I have now is a 3spd manual on the tree, what column can I look for the keeps the ignition on the dash and just turn signals on the column??
1965 Chevy Fleetside C10
If riding in an airplane is flying then riding in a boat is swimming...
If you want to experience the element get out of the vehicle!
You don't have to swap columns, you can just swap out the shifter collar for a dummy collar from a 4 speed truck. Brian
Thanks Brian that helps.
I got the collar if needed,,Brian
Socket Breaker
Socket Breaker
This was in there when I bought the truck, but I've been told that it is a 1971 chevy truck steering column... and I have a th350 transmission. I've bought 1971 parts for it and they seem to fit.
http://matraca.home.mindspring.com/img03112006/12.html
Anyway, it is an option.
I have no idea what all you'd have to do to maek it work though.
But there is a picture for ya.
-W
