10 members (1955 1 Series, Otto Skorzeny, JW51, Greg_H, Bill Hanlon, Ponchogl, Gdads51, Peggy M, TrknGMC, 1 invisible),
62
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,689 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I know this is a illegal post, but I am desperate. On my '97 Silverado 1500, I have the infamous frnt/disc-rear/drum combo. These brakes will not stop the truck when it is loaded and the brakes are warm.
What are the best pads/shoes to use. I have HD rotors with gas slots...help!
Stuart | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | There is much difference in pad quality-I like Raybestos or Wagner-usually gotta order the better pads, the garden variety $12.99 just don't work good on heavy trucks-& many shops use the cheaper pads on their "brake special",,Brian | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Get Wagner Thermo-Quiet or Severe Duty pads, best on the market. And put stock rotors back on, those slotted rotors actually have LESS braking surface than stock non slotted. Every slot or hole in the rotor surface means less area for the pad to work against.
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Baer, Memo or Stillen makes a high performance pad for hot cars but I'm unsure if they have a stock size pad for the trucks or not. May want to check into it. For more stopping power you'll want high metallic content but they will be noisy, Scott | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | I will investigate 'severe duty' pad and linings tomorrow. The reason I went to the different rotor was because I warped two sets of stockers pulling my boat over the mountain roads. So far, these aftermarket fancy rotors haven't warped, but maybe that's because the pads are so darn wimpy. I think '97 C/K 1500 rigs are a fancy flatland cruiser, not a tough tow rig for heavy loads and steep grades. My kids want me to get a Dodge/Cummins combo, but the money tree developed root rot and died. Thanks for the help on my illegal post. Stuart | | | | | Joined: Feb 2003 Posts: 452 Shop Shark | | Shop Shark Joined: Feb 2003 Posts: 452 | Considering the use of ventilated rotors in high performance racers, I believe the lack of fading and warping makes up for the slight reduction in surface area. Ventilated rotors can get rid of more heat (the main by-product of speed reduction) than plain rotors. For heavy towing, go with them. There are those who cross-drill their drums for the same reason.
Good luck
Current fleet (subject to change w/o notice) \'49 GMC 3/4-Ton , 60 Austin Healey Frog-eye Sprite (some assembly required), 2011 Dodge Avenger, 2015 Jeep Cherokee. No, they don't all run. My other ride is a (B737)no, (B767)no, A320.... Update... was Embraer E190, now Boeing B787. Knowledge is a wonderful thing, but ignorance means you don't know you can't do something.
