2 members (qside, 78buckshot), 76 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#21631 03/28/2004 2:06 PM
All,
Just purchased a very nice 69 c10 4x4, haven't owned one since the early 70's. I took it for my first drive (45 min) yesterday. I noticed after I shut it off and then restarted a few minutes later, the engine cranked very slow, almost as if the battery was weak (new battery was installed in Dec).
Any clue as to what would cause this slow cranking?
Thanks!
Joe S.
www.neatstuff2sell.com
Joe S.
69 Chevy C10 4x4
69 Mercedes Unimog 404
#21632 03/28/2004 2:47 PM
Hi Joe
Check out your starter. It probably has worn bushings and the armature is draging on the field coils. If it is kicking back and not a slow, even drag then it might be in the timing.
Truck Tinker from Talking Rock
#21633 03/28/2004 2:55 PM
If you turn on the inside cab light before cranking, you can get an idea if the system voltage is really being dragged down. Sometimes starters will start to fail in a way that they draw huge amounts of current when they are warm.
1951 1 Ton Completed
#21634 03/28/2004 3:08 PM
Another possibility: the charging system isn't working. My 60 Apache has that problem. The engine will run if the battery is charged, but it will drain the battery. Eventually there won't be enough juice to run the ignition.
#21635 03/28/2004 5:33 PM
If the spark is advanced too far it will slow the cranking speed. So will excess carbon buildup in the heads (raises effective compression ratio.)
#21636 03/28/2004 6:17 PM
If you are running headers, you may need to build a heatshield to keep the starter cooler. If it starts O.K. cold, you probably need to retard the timing until it cranks normally also.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#21637 03/28/2004 11:54 PM
Boy, you folks are a great resource, thanks for all the input!
I am waiting for the Pertronix coil, wires and electronic ignition and will check the timing out first after I install them. Process of elimination I guess!!
I will post pictures of this beauty on my website by next week.
Joe S.
69 Chevy C10 4x4
#21638 03/29/2004 3:46 AM
Junior Member
Junior Member
Be sure to check out the battery cables. they may be frayed and eaten partially away. This will cause voltage drop and make starter turn slower than normal.
