4 members (Hotrod Lincoln, Gray_Ghost, cmayna, dt235sd), 119 guests, and 0 robots.
Topics128,051
Posts1,055,732
#216302 09/24/2006 11:08 PM
I am considering replacing the bench seat in my 49 3100 1/2 ton with something "different". How many re-work the stock platform(?) or do you just it cut it off flush with the floor?
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#216303 09/25/2006 1:05 AM
It seems that most people cut it flush to the floor. It probably could be reworked though depending on the seat you're putting in.
Good Luck.
#216304 09/25/2006 2:19 AM
Junior Member
Junior Member
I am re-working mine, using power bucket seats from late model T-Bird. I was going to cut my riser out, but got worried about losing the rigidity of the floor, oilcanning etc. If I had cut out the existing riser, I would have had to build up some taller mounts for the seats that I have to work, anyway. So, I decided to leave the existing in, and put a plate and some re-inforcements under the seats.
Mark
1962 Stepside
1948 GMC
1969 Chevelle
http://mgiles5.photosite.com/
#216305 09/25/2006 1:16 PM
Just buy truck or suv seats will be the right height
