7 members (CuzzFuzz, baldeagle, kades51, frogfarmer, Brian Moore, Hotrod Lincoln, 1 invisible),
33
9
Mod | | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 63 Member | | Member Joined: Aug 2005 Posts: 63 | Yes, to be re-visited yet again...! So, I need a new heater core for my 54 deluxe heater, does anyone make one? I know one place makes the recirculator type, but I've got the 'deluxe' now... | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | Try your local radiator shop. if you have the old core they'll make one from it using it as a "pattern". I had it done a couple years back for one of my heaters. | | | | | Joined: Aug 2005 Posts: 63 Member | | Member Joined: Aug 2005 Posts: 63 | Yeah, it's $175... I was hoping to find something a little less 'spendy'... | | | | | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | I thought I got robbed but I must have been the thief. I got mine re-cored for ONLY $135. This was my reaction to the bill: I've yet to hear of anyone making a repro for the deluxe.
Mike Barnes 1950 GMC 1-ton pickup
| | | | | Joined: Aug 2005 Posts: 63 Member | | Member Joined: Aug 2005 Posts: 63 | Yeah! Well, that's what this is, a 're-core'. $175. My local guy has been great and I'll most likely have him do it, but I'm gonna check out another option first. I can't help but THINK there is a more modern heater core made that a guy could just slip into that heater plenum and make work. MAN! | | | | | Joined: Mar 2002 Posts: 990 Member | | Member Joined: Mar 2002 Posts: 990 | I went to a old stinky place and got my 72 recored for $50. | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | I spotted a nice heater on a fork lift.It would fit perfect.It would pass for a stock one.Check one out at a dealer or farm supply store
dan-pa
| | | | | Joined: Jul 2004 Posts: 78 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2004 Posts: 78 | Thats a little steep but not bad. Measure the core size (distance between the the end tanks and across the width and thickness example= 11" x 6" x 2 1/2") Sometimes a later model heater has the same core size. If that is the case a person could change tanks for less money. There are not many companies that make that type of core any more. Good Luck Steve | | | | | Joined: Oct 2003 Posts: 445 Shop Shark | | Shop Shark Joined: Oct 2003 Posts: 445 | Rrmillburn,I have what your lookin for.A heater core for a 52 and early 55. The 52 is a round core.the 55 is still in the truck.I'll set ya free at $50 + post.
dan-pa
