2 members (Cletus1950, 1955 1 Series), 93 guests, and 3 robots.
Topics128,128
Posts1,056,666
Members48,450
#215974 09/18/2006 3:01 AM
Where there aftermarket dually kits available for light duty trucks? I have a '46 3/4ton that came with an extra two wheels and extensions to make the truck into a rear, dual tire set up. The truck runs on stock 7x15 split rims.
I have never seen any information on them being an accessory or even notes in my manuals. Can somebody explain this?
I also need to replace the tires at some point. What would be a modern substitute size for the current 7x15 8 ply I'm using?
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
#215975 09/18/2006 3:08 AM
There were several companies that made those type conversions, also ther was a dual wheel factory option on 3/4 ton too, but that would have had standard dually wheels and no adapter for the rear.
In a 15", the closest would probably be a 215/75/15 or 225/75/15, but they are not being made in an 8 ply equivelant, 6 ply is the closest that is currently made. If you don't mind loosing a little originality, I'd suggest going to a 1 peice 16", preferrably for an early '80s 4x4, and a 215/85/16 E load range (10 ply).
Bill Burmeister
#215976 09/18/2006 3:22 AM
I think J.C. Whitney still sells those kits,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#215977 09/18/2006 3:23 AM
LONGBOX55,
Does the early 80's trucks have the same 8 bolt pattern and hub size? The dually adaptor I have is in good shape. Would using them put any stresses on the axle?
The dually setup would need new lugs though. It looks like it was a 12" lug nut with a threaded end. You use those to put the inner wheel on, slide the adaptor over the lugs, put the outer tire on, and then use the original lug nuts on the outer tire. The big lugs are half shot, any idea where one would find such an animal?
I'm not sure I'd use them anyway since they'ld stick outside the stakebed. It would look kind of commical.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
#215978 09/18/2006 3:29 AM
J.C. Whitney still has those kits, and they do list them for back to '45 on Chevy. The bolt pattern is the same, might be some issue with the center bore, but I think that it's minimal and can be addressed with a die grinder. I think that replacement nuts can be purchased from Whitney,too. I wouldn't worry about stressing the axle, those full-floaters are really tough.
Bill Burmeister
#215979 09/18/2006 3:39 AM
Yeah, J.C.Whitney has the kits available. Thanks for the info.
Kyle
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
#215980 09/18/2006 3:57 AM
You're welcome, LOL,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#215981 09/18/2006 4:03 AM
He's right, axle stress can break the adapte
Here is a link to some stuff about my brothers and I
http://bus-plunge.blogspot.com/search?q=hemmings
