3 members (Bill Hanlon, FishinToms53, tesa), 110 guests, and 2 robots.
Topics128,087
Posts1,056,000
Members48,430
#215965 09/18/2006 12:49 AM
Junior Member
Junior Member
are thy recomened for the older truck flat 6
is that engine cleaner junk a good idea or is it better to stay away from
You have to stand for somthing or you will fall for anything
#215966 09/18/2006 12:55 AM
Corvair, Porsche or light tank flat six?
#215967 09/18/2006 12:57 AM
Junior Member
Junior Member
im not sure what your asking
:confused:
#215968 09/18/2006 1:08 AM
I do not like any engine cleaner or oil additives. I could be wrong but I do not see the benefit. As far as v spark plugs go a mechanic friend vee-nothched a set for me but I did not find a difference in performance.
If it ain't broke don't fix it.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
#215969 09/18/2006 1:11 AM
Those are the only flat sixes I'm familiar with, so I guess we're even. If you meant inline six and tapered seat plugs, then the answer is to use the plugs with washers rather than the tapered seat type. If you give the make and year of the engine, someone can give you the plug number to buy.
#215970 09/18/2006 6:52 AM
Sorry about that, madtrapper.
I forgot that English is not your first language. The other thing an inline engine is called is a straight engine, as in straight six or straight eight, and flat is normally a synonym for straight, but not where automotive engine types are concerned. In an inline or straight configuration, the cylinders are all in a row, but in a flat engine the cylinders are arranged in opposed pairs.
Unfortunately, V-type aircraft engines are called inline engines to differentiate them from radial engines.
#215971 09/19/2006 2:22 PM
I think there may be benefits to these plugs, but the application of them in an old truck will yeild unnoticable benefits.
For an old stock truck engine, I would not waste my money. Standard plugs would my choice.
#215972 09/19/2006 9:31 PM
Are you refering to the split fire plug? If so they work just fine. But the old origional plugs do also. So I really don't see any advantage of using them. I do use them in my sons dirt bike, they seem not to foul out as often when he mixes it to rich.
As far as the engine cleaner, do you mean inside the engine? If you need an engine cleaner inside the engine its time to freashen it up with an overhaul.
If you are talking about outside of the engine, I use Castrol Super Clean, I buy it by the gallon and use it straight. (no water mix) It will remove most any petroleum product, will clean the kitchen floor, removes all wax, and is biodegradeable. Cleans white wall tires with out scrubbing also.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#215973 09/23/2006 5:27 AM
Junior Member
Junior Member
thank for the help
sorry about the late reply
i dont get much computer time
teenager
Baldy I forgot that English is not your first language
what my first lancuage
