0 members (), 136 guests, and 2 robots.
Topics128,035
Posts1,055,560
#215528 09/11/2006 7:42 PM
has anyone bought the pre-bent brake lines ? were they worth buying? or is it one of those situations where you would be better off making your own?if you bought pre-bent , who did you buy from? and would you recommend them?
thanks again
#215529 09/11/2006 7:55 PM
Inline Tube
Classic Tube
Also, many of the reproduction parts vendors sell sets from one of the above manufacturers (you can, of course, buy direct).
I have bought a few sets from Inline Tube and they fit very well. If you want to bend your own, buy the bulk stainless steel tube. I think you need a specialty tube-beeding tool to work with the double flare on a stainless-steel tube (someone who has done this will post better information).
#215530 09/11/2006 8:09 PM
Junior Member
Junior Member
I bought pre-bent stainless brake lines from Inline tube as well. Perfect fit.
#215531 09/11/2006 9:13 PM
I bought a fancy hand-hydraulic tube flaring tool, and still couldn't get a flare on stainless line. It's HARD!
Brian
#215532 09/12/2006 12:13 AM
Why bother with stainless unless you are building a show truck. Ordinary steel lines worked for a long time on these trucks, so new steel lines should outlive us.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
