1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | looking at the photos of the trucks on the last, I noticed that you guys have a single horn mounted on the exhaust manifold.. I have 3 horns that look like snails... different from what I have seen in photos, one mounted on the inside of each fender and one on the exhaust manifold... were these aftermarket or what?
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Those are most likely from either '55 and later truck or passenger car.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | A hi-note and lo-note pair of snail-like horns were GM accessories for Advance-Design trucks (at least from 1949-1955-1st, maybe back to 1947). Some people mount the pair (up through 1953) on the intake manifold or on the firewall or on the inner fender (I think there are earlier discussions of this accessory dual-horns, with links to pictures).
In 1954/55, the dual horns were mounted on the grill side of the radiator housing/frame. In these years, the standard horn (lo-note) was snail-shaped and one hi-note horn was available as an accessory. | | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | cool, then I should pull all three and work on restoring them.. cleaning them up etc..
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i would NOT mount any horn inside the fender well dirt, mud, water and crud will hurt the horn as well as plug it up w/ dust.
try the front of the radiator for the pair of Hi/Lo tone ones. aim the openings down or slightly towards the rear
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | carolines truck,
I'm not sure, but I think the mud, crud and water would be on/in the 'outer' fender well.
Isn't the inner fender well the portion, or side, inside the engine compartment, warm and well protected.
Stuart | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Stuart,
That is what I was trying to describe.
Tim | | | | | Joined: Jun 2002 Posts: 179 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 179 |
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
| | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | those are the horns... in the photo... for some reason I have 3 of them under the hood.
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | | | | Joined: Mar 2006 Posts: 483 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 483 | The reason you have 3 horns is because the previous owner thought he was a "locomotive train operator". | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Now days people just roll down their windows and yell obsceneties and show their intelligence with their middle fingers. Its like they haven't found the horn button yet. | | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | the two horns are mounted on the bracket for the radiator.. and one on the exhaust mani..
"I'd rather have a bottle in front of me than a frontal lobotomy." -D. Parker 1951 Chevy 3100 | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | Mike didn't you mention in another post in the electrical that you were having a problem with the horn relay sticking? 3 horns 1 relay I think I see the problem.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Sep 2006 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 127 | nope, the wires are cut on mine, I need to hook em up
