5 members (baldeagle, MNSmith, 46 Texaco, Shade Baby, 1 invisible), 94 guests, and 6 robots.
Topics128,018
Posts1,055,342
Members48,419
#215206 09/06/2006 10:02 PM
looking at the photos of the trucks on the last, I noticed that you guys have a single horn mounted on the exhaust manifold..
I have 3 horns that look like snails... different from what I have seen in photos, one mounted on the inside of each fender and one on the exhaust manifold...
were these aftermarket or what?
"I'd rather have a bottle in front of me than a frontal lobotomy."
-D. Parker
1951 Chevy 3100
#215207 09/06/2006 10:33 PM
Those are most likely from either '55 and later truck or passenger car.
Bill Burmeister
#215208 09/06/2006 11:12 PM
A hi-note and lo-note pair of snail-like horns were GM accessories for Advance-Design trucks (at least from 1949-1955-1st, maybe back to 1947). Some people mount the pair (up through 1953) on the intake manifold or on the firewall or on the inner fender (I think there are earlier discussions of this accessory dual-horns, with links to pictures).
In 1954/55, the dual horns were mounted on the grill side of the radiator housing/frame. In these years, the standard horn (lo-note) was snail-shaped and one hi-note horn was available as an accessory.
#215209 09/06/2006 11:39 PM
cool, then I should pull all three and work on restoring them..
cleaning them up etc..
-D. Parker
1951 Chevy 3100
#215210 09/07/2006 12:05 AM
i would NOT mount any horn inside the fender well
dirt, mud, water and crud will hurt the horn as well as plug it up w/ dust.
try the front of the radiator for the pair of Hi/Lo tone ones. aim the openings down or slightly towards the rear
Jim & Caroline
#215211 09/07/2006 12:09 AM
carolines truck,
I'm not sure, but I think the mud, crud and water would be on/in the 'outer' fender well.
Isn't the inner fender well the portion, or side, inside the engine compartment, warm and well protected.
Stuart
#215212 09/07/2006 12:16 AM
Stuart,
That is what I was trying to describe.
Tim
#215213 09/07/2006 12:19 AM
Here is where the horns are mounted on the firewall....
http://chevy.tocmp.com/1951accessories/51aim42.htm
Here is a photo...[figure106]
http://chevy.tocmp.com/1951accessories/51aim40.htm
When I go cruisin' in the old truck....women smile, men weep and dogs beg for rides.
#215214 09/07/2006 1:02 AM
those are the horns... in the photo...
for some reason I have 3 of them under the hood.
-D. Parker
1951 Chevy 3100
#215215 09/12/2006 2:25 AM
The reason you have 3 horns is because the previous owner thought he was a "locomotive train operator".
#215216 09/12/2006 8:34 PM
Now days people just roll down their windows and yell obsceneties and show their intelligence with their middle fingers. Its like they haven't found the horn button yet.
#215217 09/12/2006 9:19 PM
the two horns are mounted on the bracket for the radiator..
and one on the exhaust mani..
-D. Parker
1951 Chevy 3100
#215218 09/13/2006 4:56 AM
Mike didn't you mention in another post in the electrical that you were having a problem with the horn relay sticking? 3 horns 1 relay I think I see the problem.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
#215219 09/13/2006 1:12 PM
nope, the wires are cut on mine, I need to hook em up
-D. Parker
1951 Chevy 3100
