2 members (VicZ, oldsteve), 123 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
#214737 08/30/2006 4:15 PM
i found a motor for my 51, it's in a 49 one ton truck, what i would like to know is what size it is and will it drop in he said it had a down draft carb on it, i've never seen one so i don't realy know what he is talking about he said my 216 manifold and carb would fit it, he also thought that the motor had beerings not babbit but wasent sure it is free if i want it, he said it run's great with no noise or smoke, i need all the info on that motor i can get,, thanks,, ron
#214738 08/30/2006 4:19 PM
Grab it. Either way, if it runs it's worth it. Then take a pic, post it and one of the know-it-alls on this board will tell you things about that engine the manufacturer didn't know.
1951 3800
-hotshoe
#214739 08/30/2006 10:24 PM
Riding in the Passing Lane
You will have to get numbers & look them up to really know what it is. Practicaly all carbs. are downdraft. He might have ment updraft. Some of the stepvans had updraft carbs. The manifolds & carb off yours will fit unless its a 54 up engine.
1972 Chevy c10 Cheyenne Super
#214740 08/30/2006 10:51 PM
It might be an old COE engine if it does have an updraft,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#214741 08/31/2006 12:25 PM
thanks for the info,, i think it is a up draft becaus he said the carb was under the manifold
