| | | Forums66 Topics128,056 Posts1,055,796 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | i found a motor for my 51, it's in a 49 one ton truck, what i would like to know is what size it is and will it drop in he said it had a down draft carb on it, i've never seen one so i don't realy know what he is talking about he said my 216 manifold and carb would fit it, he also thought that the motor had beerings not babbit but wasent sure it is free if i want it, he said it run's great with no noise or smoke, i need all the info on that motor i can get,, thanks,, ron | | | | | Joined: Jul 2006 Posts: 707 Shop Shark | | Shop Shark Joined: Jul 2006 Posts: 707 | Grab it. Either way, if it runs it's worth it. Then take a pic, post it and one of the know-it-alls on this board will tell you things about that engine the manufacturer didn't know. 1951 3800 Be the change you want to see. -hotshoe
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You will have to get numbers & look them up to really know what it is. Practicaly all carbs. are downdraft. He might have ment updraft. Some of the stepvans had updraft carbs. The manifolds & carb off yours will fit unless its a 54 up engine. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It might be an old COE engine if it does have an updraft, Scott | | | | | Joined: Jun 2006 Posts: 85 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2006 Posts: 85 | thanks for the info,, i think it is a up draft becaus he said the carb was under the manifold | | |
